import page setup from one existing drawing to a new drawing
mruPRQUJ
Message 1 of 8
mruPRQUJ
Hi there,
Is it possible to create a lisp to import page setup from one existing drawing to a new drawing? thank you very much in advance! 🙂
Replies (7)
Message 2 of 8
CodeDing
EDIT:
My original reply was to import a LAYOUT from another drawing. I misread since OP wants a PAGE SETUP from another dwg
Message 3 of 8
LDShaw
Pretty sure I sent you this. You marked that one as answered so I did not bother doing more.
Here
 (command "._-PSETUPIN" "x:\\xx\\Page Setups.dwg" "3624 PDF")
 Is the dwg your pulling from
3624 pdf is the plot setup.
(if (= (strcase "3624 PDF") (strcase (vla-get-name x)))
puts the 3624 pdf as the page setup.
;;; Lisp Name: foo.lsp
;;; Author: Lonnie
;;; Date Created: 2024-07-02
;;; Last Edited: [Insert Last Edit Date]
;;; DESCRIPTION:
;;; A routine to set up page configurations by importing them from a specified DWG file.
;;; Usage:
;;; 1. Load the Lisp routine.
;;; 2. Run the command "foo" in AutoCAD.
;;; Parameters:
;;; None explicitly, but internally uses the DWG path and page setup name.
;;; Returns:
;;; None
;;; Notes:
;;; - This routine imports the "3624 PDF" page setup from the specified DWG file
;;;   ("x:\\xx\\Page Setups.dwg") and applies it to the current drawing.
;;; Related URL:
;;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/copy-objects-in-one-dwg-files-with-lots-of-layouts-sheets/td-p/12949888
;;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/set-a-page-setup-current-with-lsp/td-p/12917953
;;; ---------------------------- Main Program --------------------------------
(defun C:foo ()
  (vlax-for x
    (vla-get-plotconfigurations
      (setq d (vla-get-activedocument (vlax-get-acad-object))))
      (vl-catch-all-apply 'vla-copyfrom (list (vla-get-activelayout d) x))
Message 4 of 8
mruPRQUJ
Yes, the dwg is my pulling from 3624 pdf the plot setup.
It did not work. Could you please provide some advice to me? Could be the path wrong? Many thanks.
The information is below for your reference:
FOO
._-PSETUPIN Enter file name: C:UUsersmruDesktopBLOCKSPage Setups.dwg
"UUsersmruDesktopBLOCKSPage Setups.dwg": Can't find file.
Command: 3624 PDF Unknown command "3624 PDF". Press F1 for help.
My Lisp is below:
(defun C:foo ()
(command "._-PSETUPIN" "C:\Users\mru\Desktop\BLOCKS\Page Setups.dwg" "3624 PDF")
(vlax-for x
Message 5 of 8
LDShaw
Try this,
(defun C:foo ()
(command "._-PSETUPIN" "C:\\Users\\mru\\Desktop\\BLOCKS\\Page Setups.dwg" "3624 PDF")
(vlax-for x
If it does not work copy this in.
(defun C:listPageSetups ()
(vlax-for x (vla-get-plotconfigurations d)
(princ (strcat "\nPage Setup: " (vla-get-name x)))
(princ)
Message 6 of 8
mruPRQUJ
It works great now. Could you please advise me if the "foo" can be changed to others? how to change it? I have one lisp with "foo", thanks a lot! 🙂
Message 7 of 8
LDShaw
Nothing mysterious (defun C:foo () can be anyting you like. (defun C:hey ()
Would work just as well. Any simple editor will work. Just remember to save the file type to lsp
Message 8 of 8
mruPRQUJ
Thanks a million!
Have a wonderful day! 🙂
