Copy all block references with a given name into the current dwg using ObjectDBX
Kh.mbkh
Message 1 of 9
Kh.mbkh
Is it possible to access a set of dwg files, copy all block references on it that match a given name, and past into current dwg with original coordinates ? ( I am not sure if ObjectDBX can do it ... )
Replies (8)
Message 2 of 9
paullimapa
give attached copytocurrentdwg.lsp a try
Paul Li
IT Specialist
@The Office
Message 3 of 9
komondormrex
what is the  set of dwg files?
Message 4 of 9
Kh.mbkh
Great 👍, one more question please, is it possible to access the dwg file even if it is already opened on Acad ?
(Sometimes we want to copy blocks in all open files on Acad editor into the active document)
Thanks.
Message 5 of 9
paullimapa
I don't believe you can access a currently opened drawing. The obvious danger for this is that as another user is working on it there may have been updates in this case to the block you're wanting to copy and a save has not been performed. Then you would end up copying a block that is not up-to-date.
But if you don't care, then a way around this would be to copy the locked drawing to temp location and access the dwg in that temp location to grab your block.
@Kh.mbkh try CopyToCurrentDwgT.lsp
Paul Li
IT Specialist
@The Office
Message 6 of 9
Sea-Haven
Did you look at Lee-mac Steal lisp it allows you to simply get a block from another dwg, and can be ran without user input.
Message 7 of 9
Kh.mbkh
Thanks Paul, perfect solution !
Please, Where can I find the full documentation of ObjectDBX for AutoCAD ?
For E.g, (vla-open (list odbx copydoc)) - (vla-get-blocks oDBX) ... Where to find all method, propreties to apply for that oDBX ...
Searching on Autodesk website does not give much:
https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-FF60A11B-1169-483C-9A65-85203B3A1440
Thanks again !
Message 8 of 9
paullimapa
Well it's basically accessing the object whether it's the current active dwg:
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
or in this case the database of another dwg:
     (setq oDBX
      (vl-catch-all-apply 'vla-getinterfaceobject
       (list (vlax-get-acad-object)
        (if (< (setq oVer (atoi (getvar 'acadver))) 16)
           "objectdbx.axdbdocument"
           (strcat "objectdbx.axdbdocument." (itoa oVer))
I'd refer you to this site:
GitHub - Fraiddd/ODBX_LIB: Batch processing dwg with ODBX in Autolisp / Visual Lisp for Autocad
Paul Li
IT Specialist
@The Office
Message 9 of 9
Kh.mbkh
Lee-mac Steal lisp import a block DEFINITION from another dwg, but not block REFERENCES.
