Image overlays instead of changing
Message 1 of 9
I'm trying to create a .dcl, so when I click on an item in the list_box the image on the side will be changed.
because in my role she gets soreposta ??
is this the correct way to deal with it ??
How can I improve and leave the proof of failure ??
(defun c:demo (  )
  (defun *error* ( msg )
    (and ofile (close ofile))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **"))
    (vl-file-delete file)
    (princ)
  (defun :writedcl ( local )
    (setq file local)
    (setq ofile (open file "w"))
    (foreach line
        "butt01 : button { width = 15; height = 2; fixed_width = true; alignment = centered; }"
        "dcl_test : dialog { label = \" TEST \";"
        " spacer;"
        ": boxed_column"
        ": row"
        ":list_box  { width = 20; height = 10; fixed_width = true; key = \"lst\";  }"
        ":image  { width = 20; height = 10; key = \"img\";  }"
        "ok_cancel;"
        "} //_end"
      (write-line line ofile)
    (not (setq ofile (close ofile)))
  (cond
    ( (not (:writedcl (setq file (vl-filename-mktemp nil nil ".dcl"))))
      (alert "it was not possible to record the dcl")
    ( (<= (setq dcfname (load_dialog file)) 0)
      (alert "DCL not found")
    ( (not (new_dialog "dcl_test" dcfname))
    (t
      (setq tip '("quad" "figure 1" "figure 2"))
      (start_list "lst")
      (mapcar 'add_list tip)
      (end_list)
      (set_tile "lst" "0")
      (:vecimagem "img" quad)
      (action_tile "lst"
        (vl-prin1-to-string
          (quote
            (:vecimagem "img"
              (cond
                ( (= (nth (atoi $value) tip) "quad")
                  (setq temp quad)
                ( (= (nth (atoi $value) tip) "figure 1")
                  (setq temp fig1)
                ( (= (nth (atoi $value) tip) "figure 2")
                  (setq temp fig2)
              ) ;;cond
      (if (= (start_dialog) 1)
        (alert "Ok!")
        (alert "Cancel!")
  (if (and file (setq file (findfile file)))(vl-file-delete file))
  (princ)
(defun :vecimagem ( key lst )
  (setq i (/ (dimx_tile key) 289.) j (/ (dimy_tile key) 170.))
  (start_image key)
  (foreach x lst
    (vector_image (fix (* (car x) i))(fix (* (cadr x) j))(fix (* (caddr x) i))(fix (* (cadddr x) j))(last x))
  (end_image)
  (princ)
;;vector!!
(setq quad '((11 80 107 80 240) (107 80 107 0 240) (107 0 11 0 240) (11 0 11 80 240)))
(setq fig1 '((11 80 107 80 240) (107 80 107 0 240) (107 0 11 0 240) (11 0 11 80 240) (11 80 59 0 240) (59 0 107 80 240)))
(setq fig2 '((11 80 107 80 240) (107 80 107 0 240) (107 0 11 0 240) (11 0 11 80 240) (11 0 107 80 240) (107 0 11 80 240)))
(c:demo)
Replies (8)
Message 2 of 9
hak_vz
@AnonymousGood work. You just have to reset image before loading another one, so they don't overlap.
Also consult this post if you want to create bitmap style icons
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/dcl-button-images/m-p/9873106/highlight/true#M407589
Miljenko Hatlak
Message 3 of 9
@hak_vz
That's what I tried to do, generate a blank list and redefine the function: see the process, but without success! and it also doesn't seem like a good practice.
      (setq vas '())
      (action_tile "lst"
        (vl-prin1-to-string
          (quote
            (:vecimagem "img"
              (cond
                  (progn
                    (:vecimagem "img" vas)
                    (setq temp quad)
                  (progn
                    (setq temp fig1)
                  (progn
                    (setq temp fig2)
              ) ;;cond
Message 4 of 9
another question, I modified the DCl a little.
how would i do it when i press pick point it would allow me to go to my drawing space of the click and then go back to DCl ??
(defun c:demo (/ :writedcl nme lay rep )
    (princ)
    (setq file local)
    (foreach line
        " spacer;"
        ": boxed_column"
        ": row"
        ": row"
        ":edit_box  { width = 20; fixed_width = true; key = \"local\";  }"
        ":butt01  { fixed_width = true; key = \"pick\"; label = \"pick point\"; }"
        "ok_cancel;"
        "} //_end"
  (cond
    (t
      (start_list "lst")
      (end_list)
      (setq vas '())
      (action_tile "lst"
        (vl-prin1-to-string
          (quote
            (:vecimagem "img"
              (cond
                  (progn
                    (setq temp quad)
                  (progn
                    (setq temp fig1)
                  (progn
                    (setq temp fig2)
              ) ;;cond
      (setq local '(3074.82 1485.53 0.0)) ;;initial coordinate will be 0.0 0.0 0.0
      (set_tile "local" (strcat (rtos (car local) 2 2) "," (rtos (cadr local) 2 2)))
      (action_tile "local" (vl-prin1-to-string (quote (setq olt (get_tile "local")))))
      ;;if the user clicks on the point / marker
      (action_tile "pick" "(done_dialog 2)")
      (if (= (start_dialog) 2)
        (getpoint "pick point")
        (alert "Ok!")
        (alert "Cancel!")
  (princ)
  (start_image key)
  (foreach x lst
  (end_image)
  (princ)
;;vector!!
(setq vas '())
(c:demo)
Message 5 of 9
hak_vz
To reset image tile use this in your script before loading each vector tile
(fill_image 0 0 w h -15)
where w and h are width and height of an image tile. Color -15 is color of GUI background
About working with dcl and alowing to go back and fort between DCL and drawing I'll post my concept later. I have to look in my previous posts to this forum.
Miljenko Hatlak
Message 6 of 9
hak_vz
Here is my post about saving dcl tile values. Method uses writing and reading  dcl tile values to txt file
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/remember-previous-dcl-values-default...
Here is a sample dcl and lisp file to show a concept
There are other solutions in that post so you can use them to.
I prefer to close dcl and read it again with new value to avoid breaking display dialog chain
Miljenko Hatlak
Message 7 of 9
Thanks @hak_vz  I am grateful for the disposition.
I will analyze the links
I'm still trying to solve the problem of images.
I have already modified the function :vecimagem
  (setq dx (dimx_tile "img") dy (dimx_tile "img"))
  (start_image key)
  (fill_image 0 0 dx dy 0)
  (foreach x lst
  (end_image)
  (princ)
and action_tile even more unsuccessfully
(action_tile "lst" "(setq item (nth (atoi $value) tip))(:vecimagem \"img\" (read $value))")
Message 8 of 9
I did it !! Problem 1 solved !!!!
Message 9 of 9
hak_vz
Maybe
(fill_image 0 0 dx dy -15) instead (fill_image 0 0 dx dy 0)
Miljenko Hatlak
