Thank you for your suggestion, I actually suppress the extension lines temporarily and reduced the arrow size almost to zero, and text is aligned with the dimension line and above it.
So, I see only lines when I explode the dimensions, so I want to find the intersection of these lines and already existing polylines. There are no other line objects in the drawing before I explode the dimensions.
I searched few other posts but, couldn't find one which runs for entire drawing(without selection). Is it possible to find the intersections of "line" objects and "polyline" objects for entire drawing quickly? Say, create a circle in Zero layer or someting similar.
I also attached the drawings(created for this question), Dimensions_1 is original drawing and Dimensions_2 is after exploding the dimensions.
Thanks you all for your time.
