ERROR AND CLOSING AUTOCAD
S_S_SS
S_S_SS
Hello every one
i have a lisp when i use it AutoCAD close immediately and make error
"INTERNAL ERROR: !dbqspace.cpp@54: ePermanentlyErased"
i used the lisp more and more in the past and i didn't make edit on it never
it's the lisp from mr.leemac and the lisp command is "Stealall"
i uploaded the lisp
thanks in advance
Michiel.Valcke
I cannot recreate the error here, but there are non-ascii characters in the comments on line 218 and line 1385, which you can try to erase to see if those cause the error, that is without going looking into the code in detail.
You can also consider using the Autodesk Design Center (ADCENTER) as an alternative way to 'steal' elements from another drawing into your active drawing. Although I see Lee Mac's program allows to steal some things which the design center does not.
You could also consider to use a library of templates from which can start new designs or copybase data into. This will allow you to keep custom properties etc.. across different designs.
S_S_SS
Thanks sir ..
i just need to fix the error in this lisp
it's great and i don't understand why it doesn't work correctly now it worked in the past more and more ...
S_S_SS
Excuse me I Need your help sir
I Upload the drawing that i need to steal all from
the problem in layout steal  as i think ...
