Visual LISP, AutoLISP and General Customization
I needf help with a lisp routine
10 REPLIES 10
Message 1 of 11
714 Views, 10 Replies
Ok I know that this routine I'm posting is probably the worst way to do what
I want, but since I'm very intermediate at lisp this is the only way I could
think of.
I want to be able to cut a wall (2 lines in 2d representing a wall, not 3d),
regardless of its angle and have it cut it at the right size and put in the
end caps. Then I want it to make the endcaps the previous selection so that
I can change the layer to a wall layer all within a menu. I use this to cut
openings for doors and windows, put the added wall ends on the right layer,
then I have the menu commands take over and insert a door or window block w/
attributes, pause for insertion, pause for changing the attributes position
and angle, change the layer of the attribute, then put the door on the right
layer.
This process works for me up until the wall is at an angle other than 0, 90,
180, 360. If the wall is at a 45 then it only selects one piece. I tried to
do a window from one point to another point but it didn't seem to work, and
neither does doing a fence.
So if there is anyone that can help get this working or has a better way of
doing this I would GREATLY appreciate it. I can post the menu info if
necessary so you can see exactly what I'm doing.
David
(defun C:AC20 (/ CHS pt1 pt2 pt3 pt5 pt6 pt7 p1 p2 p3
p4 p6 p7 p8 p9 ost ang1 ang2 dist drsz hg
os an1 an2 an3 dst dst2 dsz dis osm)
(setq osm (getvar "osmode"))
(setvar "osmode" 0)
(command "undo" "mark")
;GET CORNER/MIDPOINT CHOICE
(initget "C M")
(if (not CHS)
(setq CHS "C"))
(setq temp (getkword (strcat "\nInsert Door At The Corner Or Midpoint Of
The Wall? - (C/M): < "chs" > " )))
(if temp
(setq chs temp))
;EXECUTE CORNER / MIDPOINT
(if (= chs "C")
(progn
(setvar "orthomode" 1)
(command "osnap" "int")
(setq pt1 (getpoint "\nSelect Inner Corner: "))
(command "osnap" "near")
(setq pt2 (getpoint pt1 "\nSelect Approximate Strike Or Jamb Location:
(command "osnap" "per")
(setq pt3 (getpoint pt1 "\nSelect Outside Face To Be Opened: "))
(setq ost 3)
(princ "\nOffset Distance:<")
(princ ost)
(setq dis (getdist "> "))
(setq ost (if (= dis nil)ost dis))
(setq drsz 26)
(setq ang1 (angle pt1 pt2))
(setq ang2 (angle pt1 pt3))
(setq pt4 (polar pt1 ang1 ost))
(setq pt5 (polar pt4 ang1 drsz))
(setq dist (distance pt1 pt3))
(setq pt6 (polar pt4 ang2 dist))
(setq pt7 (polar pt6 ang1 drsz))
(setvar "osmode" osm)
(command "break" pt5 pt4 "break" pt7 pt6 "line" pt5 pt7 "" "line" pt4
pt6 "")
(ssget "w" pt4 pt7))
(if (= chs "M")
(progn
(command "osnap" "int,midp")
(setq p1 (getpoint "\nSelect Intersection/Midpoint: "))
(setq p2 (getpoint p1 "\nSelect Outside Face To Be Opened: "))
(setq hg (getpoint p1 "\nSelect Approximate Hing Or Jamb Location: "))
(setq p3 (getpoint p1 "\nSelect Approximate Strike Or Jamb Location:
(setq dsz 26)
(setq os (/ dsz 2))
(setq an1 (angle p1 p3))
(setq p4 (polar p1 an1 os))
(setq an2 (angle p1 hg))
(setq p5 (polar p1 an2 os))
(setq dst (distance p1 p2))
(setq an3 (angle p1 p2))
(setq p6 (polar p5 an3 dst))
(setq p7 (polar p6 an1 dsz))
(setq dst2 (/ dst 2))
(setq p8 (polar p5 an3 dst2))
(setq p9 (polar p4 an3 dst2))
(command "break" p4 p5 "break" p7 p6 "line" p4 p7 "" "line" p5 p6 "")
(ssget "f" (list p8 p9))
) ;end AC20.lsp
10 REPLIES 10
Message 2 of 11
David,
Pretty good, for someone "very intermediate at lisp".
A few suggestions if I might:
1. Use entlast after drawing each jamb. This avoids the potential of
selecting undesireable objects.
2. Make your code modular. The code that breaks the lines and draws the
jambs is nearly identical. Make this a separate procedure called by the
main routine. Make the door size (dsz) an argument to the ac20 function
(removing the c:). Then you could call this same function from your menu to
draw multiple door sizes: (ac20 26) for a 26 inch door, or (ac20 36) for a
36 inch door.
3. Use setvar to control the running osnaps instead of commmand.
4. Keep on Lispin'
Mike Weaver
"David Munoz" wrote in message
news:637E104ACCB07141C0A2B61038147B45@in.WebX.maYIadrTaRb...
what
could
> think of.
3d),
the
that
cut
layer,
w/
position
right
> layer.
90,
to
and
of
> Thanks,
> David
> (setvar "osmode" 0)
> (initget "C M")
> (if (not CHS)
> (setq CHS "C"))
> (if temp
> (setq chs temp))
> (if (= chs "C")
> (progn
> (setq ost 3)
> (princ ost)
> (setq drsz 26)
pt4
> pt6 "")
> (if (= chs "M")
> (progn
> (setq dsz 26)
> (setq os (/ dsz 2))
> ) ;end AC20.lsp
Message 3 of 11
David,
This doesn't exactly answer your question, but is a similar progam that I did some time back. Thought you might be interested, and can maybe adapt it to your needs.
The option, offset from start point allows you to pick the corner or endpoint and start the actual opening a selected distance from that point (works well for my use).
Jesse
(defun C:DoorOpening (/ OffSet DoorOpng
StartPoint OppositeWall Direction
BreakIt
(setq OffSet (getdist "\n Amount of OFFSET from Start POINT <0>: "))
(if (not OffSet)
(setq OffSet 0)
(setq DoorOpng (getdist "\n Door Opening : "))
(setq StartPoint
(osnap
(getpoint
"\nStart (HINGE Point or HINGE Side) Of OPENING: "
"nea"
(setq Direction
(osnap
(getpoint "\n Direction of OPENING From START Point: ")
"nea"
(setvar "lastpoint" Direction)
(setq
OppositeWall
(osnap
(getpoint "\n Touch OPPOSITE Wall: "
"perp"
(setq StartPoint
(polar StartPoint (angle StartPoint Direction) OffSet)
(setq OppositePoint
(polar StartPoint
(angle Direction OppositeWall)
(distance Direction OppositeWall)
(command "line" StartPoint OppositePoint "")
(setq BreakIT (ssadd (entlast)))
(command "copy"
(entlast)
StartPoint
(polar StartPoint (angle StartPoint Direction) DoorOpng)
(command "trim"
Breakit
(entlast)
(polar StartPoint
(/ DoorOpng 2)
(polar OppositePoint
(/ DoorOpng 2)
(command "redraw")
(princ)
Message 4 of 11
Thanks for the compliment. Thanks for taking the time to offer some help. I
am a little confused with using entlast though. How do I create a selection
set of both the line I have drawn? If I do something like this:
(command
"break" pt5 pt4 "break" pt7 pt6)
(command
"line" pt5 pt7 "")
(setq en1 (entlast))
(command
"line" pt4 pt6 "")
(setq en2 (entlast))
How can I get en1 and en2 to be the previous selection set so that I may
change "previous" to a specific layer once the menu portion takes over?
Now if I make the door size an argument to the ac20 function wouldn't I have
to have input from the user for a size? I wrote a lisp for every size that I
need just so I could eliminate the user input, other than the picking of
points.
Here is a small portion of the menu so you can see what I was trying to do.
**Plfldra4_1
[1st Floor AutoCut Door In A 2x4]
[d20l90s4,2068 Left
Std]^C^Cac20;\\\\\chprop;pre;;la;a1-wall-full;;-insert;d20l90s4;endp;\;;\;-a
ttedit;;;;;last;;a;\p;\la;a1-anno-note;;chprop;last;;la;a1-door;;(menucmd
"gresidential.id_plfldra4_1=|")
Oh wait....never mind I just noticed where I would do that. Well at least
you can see what I'm trying to do with the "change previous" thing.
Once again thank you very much for the help. I really appreciate it.
Take care,
David
"Mike Weaver" wrote in message
news:48728F020942872ACE36496270CF42D6@in.WebX.maYIadrTaRb...
> David,
to
a
> 36 inch door.
> 4. Keep on Lispin'
> Mike Weaver
> what
> could
> > think of.
> 3d),
> the
> that
> cut
> layer,
block
> w/
> position
> right
> > layer.
> 90,
> to
> and
> of
> > Thanks,
> > David
> > (setvar "osmode" 0)
> > (initget "C M")
> > (if (not CHS)
> > (setq CHS "C"))
Of
> > (if temp
> > (setq chs temp))
> > (if (= chs "C")
> > (progn
> Location:
> > (setq ost 3)
> > (princ ost)
> > (setq drsz 26)
> pt4
> > pt6 "")
> > (if (= chs "M")
> > (progn
> > (setq dsz 26)
> > (setq os (/ dsz 2))
> > ) ;end AC20.lsp
Message 5 of 11
Thanks for the info. I may be able to use some of
that.
Take care,
David
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
David,
your needs.
Jesse
Direction
BreakIt
  (if (not OffSet)
    (setq OffSet 0)
  (setq StartPoint
(osnap
(getpoint
"\nStart (HINGE
"nea"
  (setq Direction
(osnap
"nea"
  (setq
    OppositeWall
     (osnap
Wall: "
       "perp"
  (setq
StartPoint
  (setq OppositePoint
(polar StartPoint
  (command
"copy"
(entlast)
StartPoint
  (command
"trim"
Breakit
(entlast)
(polar StartPoint
(angle
(/ DoorOpng 2)
(/ DoorOpng 2)
  (command "redraw")
  (princ)
Message 6 of 11
David,
I wouldn't use a seelction set. Make your AC20 routine return the enames
for the jambs as a list thus:> (command
(command
"line" pt5 pt7 "")
(setq rtlist (list (entlast)))
(command
"line" pt4 pt6 "")
(setq rtlist (append rtlist (entlast)))
then at the end of your AC20 routine, just before the closing paren put
rtlist. This will return a list with the entity names of both jambs to the
calling menu item. Which could be modified as follows to use the return
value:
**Plfldra4_1
[d20l90s4,2068 Left Std]^C^C(setq jambs (ac20
26));\\\\\chprop;pre;;la;a1-wall-full;;-insert;d20l90s4;endp;\;;\;-a
ttedit;;;;;last;;a;\p;\la;a1-anno-note;;chprop;(car jambs);(cadr
jambs);;la;a1-door;;(menucmd
Keep at it!
Mike
news:06310A24135AC6674C1ADD32702D3FBE@in.WebX.maYIadrTaRb...
I
selection
> (command
> (command
> "line" pt5 pt7 "")
> (command
> "line" pt4 pt6 "")
have
I
> points.
do.
> **Plfldra4_1
> [d20l90s4,2068 Left
> Take care,
> David
> > David,
the
menu
> to
for
> a
> > 36 inch door.
> > 4. Keep on Lispin'
> > Mike Weaver
do
> > what
> > could
> > > think of.
not
> > 3d),
in
> > the
> > that
to
> > cut
> > layer,
> block
> > w/
> > position
> > right
> > > layer.
0,
> > 90,
tried
> > to
work,
> > and
way
> > of
> > > Thanks,
> > > David
> > > (setvar "osmode" 0)
> > > (initget "C M")
> > > (if (not CHS)
> > > (setq CHS "C"))
Midpoint
> Of
> > > (if temp
> > > (setq chs temp))
> > > (if (= chs "C")
> > > (progn
> > Location:
> > > (setq ost 3)
> > > (princ ost)
> > > (setq drsz 26)
"line"
> > pt4
> > > pt6 "")
> > > (if (= chs "M")
> > > (progn
> Location:
> > > (setq dsz 26)
> > > (setq os (/ dsz 2))
p6
> > > ) ;end AC20.lsp
Message 7 of 11
Mike,
I'm confused again.... I modified the lisp routine to match what you did,
then I added rtlist right before the last closing paren and I got this error
; error: bad argument type: listp
I took out the rtlist before the last closing paren and it gave me:
I took out the (setq rtlist (append rtlist (entlast))) part and get a nil at
the end of the routine.
I think I understand what you're talking about with the(car jambs) and (cadr
jambs) but I'm not completely sure.
By doing (setq jambs(ac20 26)) is this supposed to execute the ac20 lisp and
if so what is the 26 for? Now by putting rtlist at
the end of the ac20 lisp does that leave the rtlist value available for
setting the jambs variable to? That would be why you would step through the
jambs variable with car and cadr right? Car would extract the first jamb and
cadr would extract the second jamb right? I can't get (setq jambs(ac20 26))
or (setq jambs(ac20)) to work. it just gives me ; error: no function
definition: AC20. I did (setq jambs(c:ac20)) which executed the ac20 lisp
but I still got the above list errors and jambs is set to nil.
Once again thanks for taking the time to help me out. I appreciate it.
Dave
news:B449CFD09218E49CD33036845A7377A1@in.WebX.maYIadrTaRb...
> David,
> (command
> "line" pt5 pt7 "")
> (command
> "line" pt4 pt6 "")
the
> value:
> **Plfldra4_1
> Keep at it!
> Mike
help.
> I
> selection
> > (command
> > (command
> > "line" pt5 pt7 "")
> > (command
> > "line" pt4 pt6 "")
> have
that
> I
> > points.
> do.
> > **Plfldra4_1
> > [d20l90s4,2068 Left
least
> > Take care,
> > David
> > > David,
> the
the
function
> menu
> > to
> for
> > a
> > > 36 inch door.
> > > 4. Keep on Lispin'
> > > Mike Weaver
> do
> > > what
I
> > > could
> > > > think of.
> not
> > > 3d),
> in
> > > the
so
> > > that
> to
> > > cut
> > > layer,
> > block
> > > w/
> > > position
the
> > > right
> > > > layer.
than
> 0,
> > > 90,
> tried
> > > to
> work,
> > > and
> way
> > > of
if
> > > > Thanks,
> > > > David
> > > > (setvar "osmode" 0)
> > > > (initget "C M")
> > > > (if (not CHS)
> > > > (setq CHS "C"))
> Midpoint
> > Of
> > > > (if temp
> > > > (setq chs temp))
> > > > (if (= chs "C")
> > > > (progn
> > > Location:
> > > > (setq ost 3)
> > > > (princ ost)
> > > > (setq drsz 26)
> "line"
> > > pt4
> > > > pt6 "")
> > > > (if (= chs "M")
> > > > (progn
> Location:
> > Location:
> > > > (setq dsz 26)
> > > > (setq os (/ dsz 2))
> p6
> > > > ) ;end AC20.lsp
Message 8 of 11
David,
See the attached.
The error messages you're getting are telling you a couple of things:
First the error is due to a bad argument type
Second, the argument type expected was a list
Third, the value supplied for the argument - in this case, an entity name
The append function requires lists for the arguments. So:
(setq rtlist (append (list (entlast)) rtlist))
should solve the problem. The attached file does this without using
append - simply combines the two return values into a list at the end of the
routine.
You'll see in the attached file that I have modified ac20 to require a
single argument - the value for the function drsz - in this case 26. Also,
at the end of the procedure, I've added (list en1 en2) so that these entity
names will be returned and can be accessed using car and cadr - just as you
recognized.
You go tthe no function definition error because your ac20 function has the
leading C:. The only reason for the C: is to make the function available
without parens. If we are going to be using drsz as an argument we have to
enclose it in parens and the C: then does nothing for us.
Supplying the door size (drsz) to the function as an argument allows you to
use the same code for all door sizes - no more changing the routines for
each door size when you have a change.
Mike Weaver
news:E27F6B51B2A46239421002C9FFAFF217@in.WebX.maYIadrTaRb...
> Mike,
error
at
(cadr
and
the
and
26))
> Dave
> > David,
enames
> > (command
> > "line" pt5 pt7 "")
> > (command
> > "line" pt4 pt6 "")
> the
> > value:
> > **Plfldra4_1
> > Keep at it!
> > Mike
> help.
> > I
> > selection
> > > (command
> > > (command
> > > "line" pt5 pt7 "")
> > > (command
> > > "line" pt4 pt6 "")
may
over?
I
> > have
> that
> > I
of
> > > points.
to
> > do.
> > > **Plfldra4_1
> > > [d20l90s4,2068 Left
> least
> > > Take care,
> > > David
> > > > David,
of
draws
> > the
> the
> function
> > menu
> > > to
36)
> > for
> > > a
> > > > 36 inch door.
> > > > 4. Keep on Lispin'
> > > > Mike Weaver
to
> > do
> > > > what
way
> I
> > > > could
> > > > > think of.
wall,
> > not
> > > > 3d),
put
> > in
> > > > the
selection
> so
> > > > that
this
> > to
> > > > cut
right
> > > > layer,
window
> > > block
> > > > w/
> > > > position
> the
> > > > right
> > > > > layer.
> than
> > 0,
> > > > 90,
> > tried
> > > > to
> > work,
> > > > and
better
> > way
> > > > of
> if
> > > > > Thanks,
> > > > > David
> > > > > (setvar "osmode" 0)
> > > > > (initget "C M")
> > > > > (if (not CHS)
> > > > > (setq CHS "C"))
> > Midpoint
> > > Of
> > > > > (if temp
> > > > > (setq chs temp))
> > > > > (if (= chs "C")
> > > > > (progn
> > > > Location:
> > > > > (setq ost 3)
> > > > > (princ ost)
> > > > > (setq drsz 26)
> > "line"
> > > > pt4
> > > > > pt6 "")
> > > > > (if (= chs "M")
> > > > > (progn
> > Location:
> > > Location:
> > > > > (setq dsz 26)
> > > > > (setq os (/ dsz 2))
p5
> > p6
> > > > > ) ;end AC20.lsp
Message 9 of 11
WOW that works perfect. I did not know that it could be done that way. The
only thing I need a little help understanding is how does it know to set the
value for dsrz to 26. Is it because it is in the local variable section
(drsz / etc.....) and is the only thing not defined? I understand all the
rest of it now, but that's kind of unclear. If that's the case then it would
only be possible to have one instance like that per function, correct?
Once again I have to say thank you VERY much for taking the time to explain
this to me. I really really appreciate it. It has help me a great deal.
Take care,
David
news:98BB3599A9B5BC83DF8CF8D0B7967D74@in.WebX.maYIadrTaRb...
> David,
> See the attached.
name
the
> routine.
Also,
entity
you
> recognized.
the
to
to
> Mike Weaver
> > Mike,
did,
> error
nil
> at
> (cadr
> and
> the
> and
> 26))
lisp
> > Dave
> > > David,
> enames
> > > (command
> > > "line" pt5 pt7 "")
> > > (command
> > > "line" pt4 pt6 "")
put
to
> > the
return
> > > value:
> > > **Plfldra4_1
> > > Keep at it!
> > > Mike
> > help.
> > > I
> > > selection
> > > > (command
> > > > (command
> > > > "line" pt5 pt7 "")
> > > > (command
> > > > "line" pt4 pt6 "")
> may
> over?
wouldn't
> I
> > > have
size
> > that
> > > I
picking
> of
> > > > points.
> to
> > > do.
> > > > **Plfldra4_1
> > > > [d20l90s4,2068 Left
> > least
> > > > Take care,
> > > > David
> > > > > David,
potential
> of
> draws
> > > the
by
> > the
> > function
your
> > > menu
> > > > to
> 36)
> > > for
> > > > a
> > > > > 36 inch door.
> > > > > 4. Keep on Lispin'
> > > > > Mike Weaver
way
> to
> > > do
> > > > > what
> way
> > I
> > > > > could
> > > > > > think of.
> wall,
> > > not
> > > > > 3d),
> put
> > > in
> > > > > the
> selection
> > so
> > > > > that
> this
> > > to
> > > > > cut
> right
> > > > > layer,
> window
> > > > block
> > > > > w/
attributes
> > > > > position
on
> > the
> > > > > right
> > > > > > layer.
> > than
> > > 0,
> > > > > 90,
I
> > > tried
> > > > > to
to
> > > work,
> > > > > and
> better
> > > way
> > > > > of
info
> > if
> > > > > > Thanks,
> > > > > > David
p3
> > > > > > (setvar "osmode" 0)
> > > > > > (initget "C M")
> > > > > > (if (not CHS)
> > > > > > (setq CHS "C"))
> > > Midpoint
> > > > Of
> > > > > > (if temp
> > > > > > (setq chs temp))
> > > > > > (if (= chs "C")
> > > > > > (progn
Jamb
> > > > > Location:
Opened:
> > > > > > (setq ost 3)
> > > > > > (princ ost)
> > > > > > (setq drsz 26)
> > > "line"
> > > > > pt4
> > > > > > pt6 "")
> > > > > > (if (= chs "M")
> > > > > > (progn
> > > Location:
> > > > Location:
> > > > > > (setq dsz 26)
> > > > > > (setq os (/ dsz 2))
"line"
> p5
> > > p6
> > > > > > ) ;end AC20.lsp
(defun AC20 (drsz / CHS pt1 pt2 pt3 pt5 pt6 pt7 p1 p2 p3
os an1 an2 an3 dst dst2 dsz dis osm en1 en2)
(setvar "osmode" 0)
(initget "C M")
(if (not CHS)
(setq CHS "C"))
(if temp
(setq chs temp))
(if (= chs "C")
(progn
(setq ost 3)
(princ ost)
;;(setq drsz 26)
(command "break" pt5 pt4 "break" pt7 pt6 "line" pt5 pt7 "")
(command "line" pt4 pt6 "")
;;(ssget "w" pt4 pt7))
(if (= chs "M")
(progn
;;(setq dsz 26)
(setq os (/ dsz 2))
(command "break" p4 p5 "break" p7 p6 "line" p4 p7 "")
(command "line" p5 p6 "")
;;(ssget "f" (list p8 p9))
(list en1 en2)
) ;end AC20.lsp
Message 10 of 11
I'm glad it works!
The local variables section has two areas separated by the foreward slash.
The vars in the first area are declared arguments, those in the second are
localized vars. For example:
(defun test(arg1 arg2 / var1 var2)
(princ (strcat "\n" arg1 "\t" arg2))
(princ)
defines arg1 and arg2 as arguments, var1 and var2 as local variables. When
calling this function, you have to supply values for arg1 and arg2 as
follows:
(test "Value for first argument" "value for second argument")
will print:
Value for first argument value for second argument
So. For your AC20 routine, you can draw 26 inch doors with: (ac20 26) and
36 inch doors with (ac20 36). You can now draw any width door with that
single routine - no need for different routines for each door width.
I create nearly all of my sub-routines to take required input as arguments
and return some value to the calling routine. I very seldom use global
variables for passing information between routines.
Mike Weaver
news:9BCC5ACAA21739FBE4625CA449D77F16@in.WebX.maYIadrTaRb...
the
would
explain
> Take care,
> David
> > David,
> > See the attached.
> name
> the
> > routine.
> Also,
> entity
> you
> > recognized.
> the
available
> to
> to
> > Mike Weaver
> > > Mike,
> did,
> > error
> nil
> > at
> > (cadr
lisp
> > and
for
through
> > the
jamb
> > and
> > 26))
> lisp
> > > Dave
> > > > David,
> > enames
> > > > (command
> > > > "line" pt5 pt7 "")
> > > > (command
> > > > "line" pt4 pt6 "")
> put
> to
> > > the
> return
> > > > value:
> > > > **Plfldra4_1
> > > > Keep at it!
> > > > Mike
some
> > > help.
> > > > I
> > > > selection
> > > > > (command
> > > > > (command
> > > > > "line" pt5 pt7 "")
> > > > > (command
> > > > > "line" pt4 pt6 "")
I
> > may
> > over?
> wouldn't
> > I
> > > > have
> size
> > > that
> > > > I
> picking
> > of
> > > > > points.
trying
> > to
> > > > do.
> > > > > **Plfldra4_1
> > > > > [d20l90s4,2068 Left
at
> > > least
thing.
it.
> > > > > Take care,
> > > > > David
> > > > > > David,
> potential
> > of
> > draws
> > > > the
called
> by
> > > the
> > > function
> your
> > > > menu
> > > > > to
(ac20
> > 36)
> > > > for
> > > > > a
> > > > > > 36 inch door.
commmand.
> > > > > > 4. Keep on Lispin'
> > > > > > Mike Weaver
> way
> > to
> > > > do
> > > > > > what
only
> > way
> > > I
> > > > > > could
> > > > > > > think of.
> > wall,
> > > > not
> > > > > > 3d),
and
> > put
> > > > in
> > > > > > the
> > selection
> > > so
> > > > > > that
use
> > this
> > > > to
> > > > > > cut
> > right
> > > > > > layer,
> > window
> > > > > block
> > > > > > w/
> attributes
> > > > > > position
door
> on
> > > the
> > > > > > right
> > > > > > > layer.
other
> > > than
> > > > 0,
> > > > > > 90,
piece.
> I
> > > > tried
> > > > > > to
> to
> > > > work,
> > > > > > and
> > better
> > > > way
> > > > > > of
> info
> > > if
> > > > > > > Thanks,
> > > > > > > David
> p3
> > > > > > > (setvar "osmode" 0)
> > > > > > > (initget "C M")
> > > > > > > (if (not CHS)
> > > > > > > (setq CHS "C"))
> > > > Midpoint
> > > > > Of
> > > > > > > (if temp
> > > > > > > (setq chs temp))
> > > > > > > (if (= chs "C")
> > > > > > > (progn
> Jamb
> > > > > > Location:
> Opened:
> > > > > > > (setq ost 3)
> > > > > > > (princ ost)
> > > > > > > (setq drsz 26)
> > > > "line"
> > > > > > pt4
> > > > > > > pt6 "")
> > > > > > > (if (= chs "M")
> > > > > > > (progn
Opened:
> > > > Location:
Jamb
> > > > > Location:
> > > > > > > (setq dsz 26)
> > > > > > > (setq os (/ dsz 2))
> "line"
> > p5
> > > > p6
> > > > > > > ) ;end AC20.lsp
> (setvar "osmode" 0)
> (initget "C M")
> (if (not CHS)
> (setq CHS "C"))
> (if temp
> (setq chs temp))
> (if (= chs "C")
> (progn
> Location:"))
> (setq ost 3)
> (princ ost)
> ;;(setq drsz 26)
> (if (= chs "M")
> (progn
> Location:"))
> ;;(setq dsz 26)
> (setq os (/ dsz 2))
> (list en1 en2)
> ) ;end AC20.lsp
Message 11 of 11
Well that pretty much clears it up. Thanks a whole bunch. I have learned a
great deal from this.
Well.........take care, and as you said before....Keep on lispin'
Dave Munoz
news:E367027836D819809FECED10EEA9F6D7@in.WebX.maYIadrTaRb...
> I'm glad it works!
> (princ)
When
> follows:
> will print:
> Mike Weaver
The
> the
the
> would
> explain
> > Take care,
> > David
> > > David,
> > > See the attached.
entity
> > name
of
> > the
> > > routine.
> > Also,
> > entity
as
> > you
> > > recognized.
has
> > the
> available
have
> > to
you
> > to
for
> > > Mike Weaver
> > > > Mike,
> > did,
this
> > > error
a
> > nil
> > > at
and
> > > (cadr
> lisp
> > > and
> for
> through
> > > the
> jamb
> > > and
jambs(ac20
> > > 26))
> > lisp
it.
> > > > Dave
> > > > > David,
> > > enames
> > > > > (command
> > > > > "line" pt5 pt7 "")
> > > > > (command
> > > > > "line" pt4 pt6 "")
paren
> > put
jambs
> > to
> > > > the
> > return
> > > > > value:
> > > > > **Plfldra4_1
> > > > > Keep at it!
> > > > > Mike
> some
> > > > help.
> > > > > I
a
> > > > > selection
> > > > > > (command
> > > > > > (command
> > > > > > "line" pt5 pt7 "")
> > > > > > (command
> > > > > > "line" pt4 pt6 "")
that
> I
> > > may
takes
> > > over?
> > wouldn't
> > > I
> > > > > have
> > size
> > > > that
> > > > > I
> > picking
> > > of
> > > > > > points.
> trying
> > > to
> > > > > do.
> > > > > > **Plfldra4_1
> > > > > > [d20l90s4,2068 Left
> at
> > > > least
> thing.
> it.
> > > > > > Take care,
> > > > > > David
> > > > > > > David,
> > potential
> > > of
and
> > > draws
> > > > > the
> called
> > by
> > > > the
ac20
> > > > function
from
> > your
> > > > > menu
> > > > > > to
> (ac20
> > > 36)
> > > > > for
> > > > > > a
> > > > > > > 36 inch door.
> commmand.
> > > > > > > 4. Keep on Lispin'
> > > > > > > Mike Weaver
worst
> > way
> > > to
> > > > > do
> > > > > > > what
> only
> > > way
> > > > I
> > > > > > > could
> > > > > > > > think of.
a
> > > wall,
> > > > > not
> > > > > > > 3d),
> and
> > > put
> > > > > in
> > > > > > > the
> > > selection
> > > > so
> > > > > > > that
> use
> > > this
> > > > > to
> > > > > > > cut
the
> > > right
> > > > > > > layer,
> > > window
> > > > > > block
> > > > > > > w/
> > attributes
> > > > > > > position
> door
> > on
> > > > the
> > > > > > > right
> > > > > > > > layer.
> other
> > > > than
> > > > > 0,
> > > > > > > 90,
> piece.
> > I
> > > > > tried
> > > > > > > to
seem
> > to
> > > > > work,
> > > > > > > and
a
> > > better
> > > > > way
> > > > > > > of
menu
> > info
> > > > if
> > > > > > > > Thanks,
> > > > > > > > David
p2
> > p3
> > > > > > > > (setvar "osmode" 0)
> > > > > > > > (initget "C M")
> > > > > > > > (if (not CHS)
> > > > > > > > (setq CHS "C"))
Or
> > > > > Midpoint
> > > > > > Of
> > > > > > > > (if temp
> > > > > > > > (setq chs temp))
> > > > > > > > (if (= chs "C")
> > > > > > > > (progn
Or
> > Jamb
> > > > > > > Location:
> > Opened:
> > > > > > > > (setq ost 3)
> > > > > > > > (princ ost)
> > > > > > > > (setq drsz 26)
pt7
> > > > > "line"
> > > > > > > pt4
> > > > > > > > pt6 "")
> > > > > > > > (if (= chs "M")
> > > > > > > > (progn
> Opened:
Jamb
> > > > > Location:
> Jamb
> > > > > > Location:
> > > > > > > > (setq dsz 26)
> > > > > > > > (setq os (/ dsz 2))
> > "line"
> > > p5
> > > > > p6
> > > > > > > > ) ;end AC20.lsp
> > (setvar "osmode" 0)
> > (initget "C M")
> > (if (not CHS)
> > (setq CHS "C"))
Of
> > (if temp
> > (setq chs temp))
> > (if (= chs "C")
> > (progn
> > Location:"))
> > (setq ost 3)
> > (princ ost)
> > ;;(setq drsz 26)
> > (if (= chs "M")
> > (progn
> > Location:"))
> > ;;(setq dsz 26)
> > (setq os (/ dsz 2))
> > (list en1 en2)
> > ) ;end AC20.lsp
AutoCAD Inside the Factory
