Well that pretty much clears it up. Thanks a whole bunch. I have learned a
great deal from this.
Well.........take care, and as you said before....Keep on lispin'
Dave Munoz
"Mike Weaver" wrote in message
news:E367027836D819809FECED10EEA9F6D7@in.WebX.maYIadrTaRb...
> I'm glad it works!
> The local variables section has two areas separated by the foreward slash.
> The vars in the first area are declared arguments, those in the second are
> localized vars. For example:
> (defun test(arg1 arg2 / var1 var2)
> (princ (strcat "\n" arg1 "\t" arg2))
> (princ)
> defines arg1 and arg2 as arguments, var1 and var2 as local variables.
When
> calling this function, you have to supply values for arg1 and arg2 as
> follows:
> (test "Value for first argument" "value for second argument")
> will print:
> Value for first argument value for second argument
> So. For your AC20 routine, you can draw 26 inch doors with: (ac20 26) and
> 36 inch doors with (ac20 36). You can now draw any width door with that
> single routine - no need for different routines for each door width.
> I create nearly all of my sub-routines to take required input as arguments
> and return some value to the calling routine. I very seldom use global
> variables for passing information between routines.
> Mike Weaver
> "David Munoz" wrote in message
> news:9BCC5ACAA21739FBE4625CA449D77F16@in.WebX.maYIadrTaRb...
> > WOW that works perfect. I did not know that it could be done that way.
The
> > only thing I need a little help understanding is how does it know to set
> the
> > value for dsrz to 26. Is it because it is in the local variable section
> > (drsz / etc.....) and is the only thing not defined? I understand all
the
> > rest of it now, but that's kind of unclear. If that's the case then it
> would
> > only be possible to have one instance like that per function, correct?
> > Once again I have to say thank you VERY much for taking the time to
> explain
> > this to me. I really really appreciate it. It has help me a great deal.
> > Take care,
> > David
> > news:98BB3599A9B5BC83DF8CF8D0B7967D74@in.WebX.maYIadrTaRb...
> > > David,
> > > See the attached.
> > > The error messages you're getting are telling you a couple of things:
> > > First the error is due to a bad argument type
> > > Second, the argument type expected was a list
> > > Third, the value supplied for the argument - in this case, an
entity
> > name
> > > The append function requires lists for the arguments. So:
> > > (setq rtlist (append (list (entlast)) rtlist))
> > > should solve the problem. The attached file does this without using
> > > append - simply combines the two return values into a list at the end
of
> > the
> > > routine.
> > > You'll see in the attached file that I have modified ac20 to require a
> > > single argument - the value for the function drsz - in this case 26.
> > Also,
> > > at the end of the procedure, I've added (list en1 en2) so that these
> > entity
> > > names will be returned and can be accessed using car and cadr - just
as
> > you
> > > recognized.
> > > You go tthe no function definition error because your ac20 function
has
> > the
> > > leading C:. The only reason for the C: is to make the function
> available
> > > without parens. If we are going to be using drsz as an argument we
have
> > to
> > > enclose it in parens and the C: then does nothing for us.
> > > Supplying the door size (drsz) to the function as an argument allows
you
> > to
> > > use the same code for all door sizes - no more changing the routines
for
> > > each door size when you have a change.
> > > Mike Weaver
> > > news:E27F6B51B2A46239421002C9FFAFF217@in.WebX.maYIadrTaRb...
> > > > Mike,
> > > > I'm confused again.... I modified the lisp routine to match what you
> > did,
> > > > then I added rtlist right before the last closing paren and I got
this
> > > error
> > > > ; error: bad argument type: listp
> > > > I took out the rtlist before the last closing paren and it gave me:
> > > > I took out the (setq rtlist (append rtlist (entlast))) part and get
a
> > nil
> > > at
> > > > the end of the routine.
> > > > I think I understand what you're talking about with the(car jambs)
and
> > > (cadr
> > > > jambs) but I'm not completely sure.
> > > > By doing (setq jambs(ac20 26)) is this supposed to execute the ac20
> lisp
> > > and
> > > > if so what is the 26 for? Now by putting rtlist at
> > > > the end of the ac20 lisp does that leave the rtlist value available
> for
> > > > setting the jambs variable to? That would be why you would step
> through
> > > the
> > > > jambs variable with car and cadr right? Car would extract the first
> jamb
> > > and
> > > > cadr would extract the second jamb right? I can't get (setq
jambs(ac20
> > > 26))
> > > > or (setq jambs(ac20)) to work. it just gives me ; error: no function
> > > > definition: AC20. I did (setq jambs(c:ac20)) which executed the ac20
> > lisp
> > > > but I still got the above list errors and jambs is set to nil.
> > > > Once again thanks for taking the time to help me out. I appreciate
it.
> > > > Dave
> > > > news:B449CFD09218E49CD33036845A7377A1@in.WebX.maYIadrTaRb...
> > > > > David,
> > > > > I wouldn't use a seelction set. Make your AC20 routine return the
> > > enames
> > > > > for the jambs as a list thus:> (command
> > > > > "break" pt5 pt4 "break" pt7 pt6)
> > > > > (command
> > > > > "line" pt5 pt7 "")
> > > > > (setq rtlist (list (entlast)))
> > > > > (command
> > > > > "line" pt4 pt6 "")
> > > > > then at the end of your AC20 routine, just before the closing
paren
> > put
> > > > > rtlist. This will return a list with the entity names of both
jambs
> > to
> > > > the
> > > > > calling menu item. Which could be modified as follows to use the
> > return
> > > > > value:
> > > > > **Plfldra4_1
> > > > > [1st Floor AutoCut Door In A 2x4]
> > > > > [d20l90s4,2068 Left Std]^C^C(setq jambs (ac20
26));\\\\\chprop;pre;;la;a1-wall-full;;-insert;d20l90s4;endp;\;;\;-a
> > > > > ttedit;;;;;last;;a;\p;\la;a1-anno-note;;chprop;(car jambs);(cadr
> > > > > jambs);;la;a1-door;;(menucmd
> > > > > "gresidential.id_plfldra4_1=|")
> > > > > Keep at it!
> > > > > Mike
> > > > > news:06310A24135AC6674C1ADD32702D3FBE@in.WebX.maYIadrTaRb...
> > > > > > Thanks for the compliment. Thanks for taking the time to offer
> some
> > > > help.
> > > > > I
> > > > > > am a little confused with using entlast though. How do I create
a
> > > > > selection
> > > > > > set of both the line I have drawn? If I do something like this:
> > > > > > (command
> > > > > > (command
> > > > > > "line" pt5 pt7 "")
> > > > > > (setq en1 (entlast))
> > > > > > (command
> > > > > > "line" pt4 pt6 "")
> > > > > > (setq en2 (entlast))
> > > > > > How can I get en1 and en2 to be the previous selection set so
that
> I
> > > may
> > > > > > change "previous" to a specific layer once the menu portion
takes
> > > over?
> > > > > > Now if I make the door size an argument to the ac20 function
> > wouldn't
> > > I
> > > > > have
> > > > > > to have input from the user for a size? I wrote a lisp for every
> > size
> > > > that
> > > > > I
> > > > > > need just so I could eliminate the user input, other than the
> > picking
> > > of
> > > > > > points.
> > > > > > Here is a small portion of the menu so you can see what I was
> trying
> > > to
> > > > > do.
> > > > > > **Plfldra4_1
> > > > > > [d20l90s4,2068 Left
Std]^C^Cac20;\\\\\chprop;pre;;la;a1-wall-full;;-insert;d20l90s4;endp;\;;\;-a
ttedit;;;;;last;;a;\p;\la;a1-anno-note;;chprop;last;;la;a1-door;;(menucmd
> > > > > > Oh wait....never mind I just noticed where I would do that. Well
> at
> > > > least
> > > > > > you can see what I'm trying to do with the "change previous"
> thing.
> > > > > > Once again thank you very much for the help. I really appreciate
> it.
> > > > > > Take care,
> > > > > > David
> > > > > > news:48728F020942872ACE36496270CF42D6@in.WebX.maYIadrTaRb...
> > > > > > > David,
> > > > > > > Pretty good, for someone "very intermediate at lisp".
> > > > > > > A few suggestions if I might:
> > > > > > > 1. Use entlast after drawing each jamb. This avoids the
> > potential
> > > of
> > > > > > > selecting undesireable objects.
> > > > > > > 2. Make your code modular. The code that breaks the lines
and
> > > draws
> > > > > the
> > > > > > > jambs is nearly identical. Make this a separate procedure
> called
> > by
> > > > the
> > > > > > > main routine. Make the door size (dsz) an argument to the
ac20
> > > > function
> > > > > > > (removing the c:). Then you could call this same function
from
> > your
> > > > > menu
> > > > > > to
> > > > > > > draw multiple door sizes: (ac20 26) for a 26 inch door, or
> (ac20
> > > 36)
> > > > > for
> > > > > > a
> > > > > > > 36 inch door.
> > > > > > > 3. Use setvar to control the running osnaps instead of
> commmand.
> > > > > > > 4. Keep on Lispin'
> > > > > > > Mike Weaver
> > > > > > > news:637E104ACCB07141C0A2B61038147B45@in.WebX.maYIadrTaRb...
> > > > > > > > Ok I know that this routine I'm posting is probably the
worst
> > way
> > > to
> > > > > do
> > > > > > > what
> > > > > > > > I want, but since I'm very intermediate at lisp this is the
> only
> > > way
> > > > I
> > > > > > > could
> > > > > > > > think of.
> > > > > > > > I want to be able to cut a wall (2 lines in 2d representing
a
> > > wall,
> > > > > not
> > > > > > > 3d),
> > > > > > > > regardless of its angle and have it cut it at the right size
> and
> > > put
> > > > > in
> > > > > > > the
> > > > > > > > end caps. Then I want it to make the endcaps the previous
> > > selection
> > > > so
> > > > > > > that
> > > > > > > > I can change the layer to a wall layer all within a menu. I
> use
> > > this
> > > > > to
> > > > > > > cut
> > > > > > > > openings for doors and windows, put the added wall ends on
the
> > > right
> > > > > > > layer,
> > > > > > > > then I have the menu commands take over and insert a door or
> > > window
> > > > > > block
> > > > > > > w/
> > > > > > > > attributes, pause for insertion, pause for changing the
> > attributes
> > > > > > > position
> > > > > > > > and angle, change the layer of the attribute, then put the
> door
> > on
> > > > the
> > > > > > > right
> > > > > > > > layer.
> > > > > > > > This process works for me up until the wall is at an angle
> other
> > > > than
> > > > > 0,
> > > > > > > 90,
> > > > > > > > 180, 360. If the wall is at a 45 then it only selects one
> piece.
> > I
> > > > > tried
> > > > > > > to
> > > > > > > > do a window from one point to another point but it didn't
seem
> > to
> > > > > work,
> > > > > > > and
> > > > > > > > neither does doing a fence.
> > > > > > > > So if there is anyone that can help get this working or has
a
> > > better
> > > > > way
> > > > > > > of
> > > > > > > > doing this I would GREATLY appreciate it. I can post the
menu
> > info
> > > > if
> > > > > > > > necessary so you can see exactly what I'm doing.
> > > > > > > > Thanks,
> > > > > > > > David
> > > > > > > > (defun C:AC20 (/ CHS pt1 pt2 pt3 pt5 pt6 pt7 p1
p2
> > p3
> > > > > > > > p4 p6 p7 p8 p9 ost ang1 ang2 dist drsz hg
> > > > > > > > os an1 an2 an3 dst dst2 dsz dis osm)
> > > > > > > > (setq osm (getvar "osmode"))
> > > > > > > > (setvar "osmode" 0)
> > > > > > > > (command "undo" "mark")
> > > > > > > > ;GET CORNER/MIDPOINT CHOICE
> > > > > > > > (initget "C M")
> > > > > > > > (if (not CHS)
> > > > > > > > (setq CHS "C"))
> > > > > > > > (setq temp (getkword (strcat "\nInsert Door At The Corner
Or
> > > > > Midpoint
> > > > > > Of
> > > > > > > > The Wall? - (C/M): < "chs" > " )))
> > > > > > > > (if temp
> > > > > > > > (setq chs temp))
> > > > > > > > ;EXECUTE CORNER / MIDPOINT
> > > > > > > > (if (= chs "C")
> > > > > > > > (progn
> > > > > > > > (setvar "orthomode" 1)
> > > > > > > > (command "osnap" "int")
> > > > > > > > (setq pt1 (getpoint "\nSelect Inner Corner: "))
> > > > > > > > (command "osnap" "near")
> > > > > > > > (setq pt2 (getpoint pt1 "\nSelect Approximate Strike
Or
> > Jamb
> > > > > > > Location:
> > > > > > > > (command "osnap" "per")
> > > > > > > > (setq pt3 (getpoint pt1 "\nSelect Outside Face To Be
> > Opened:
> > > > > > > > (setq ost 3)
> > > > > > > > (princ "\nOffset Distance:<")
> > > > > > > > (princ ost)
> > > > > > > > (setq dis (getdist "> "))
> > > > > > > > (setq ost (if (= dis nil)ost dis))
> > > > > > > > (setq drsz 26)
> > > > > > > > (setq ang1 (angle pt1 pt2))
> > > > > > > > (setq ang2 (angle pt1 pt3))
> > > > > > > > (setq pt4 (polar pt1 ang1 ost))
> > > > > > > > (setq pt5 (polar pt4 ang1 drsz))
> > > > > > > > (setq dist (distance pt1 pt3))
> > > > > > > > (setq pt6 (polar pt4 ang2 dist))
> > > > > > > > (setq pt7 (polar pt6 ang1 drsz))
> > > > > > > > (setvar "osmode" osm)
> > > > > > > > (command "break" pt5 pt4 "break" pt7 pt6 "line" pt5
pt7
> > > > > "line"
> > > > > > > pt4
> > > > > > > > pt6 "")
> > > > > > > > (ssget "w" pt4 pt7))
> > > > > > > > (if (= chs "M")
> > > > > > > > (progn
> > > > > > > > (command "osnap" "int,midp")
> > > > > > > > (setq p1 (getpoint "\nSelect Intersection/Midpoint:
> > > > > > > > (setq p2 (getpoint p1 "\nSelect Outside Face To Be
> Opened:
> > > > > > > > (setq hg (getpoint p1 "\nSelect Approximate Hing Or
Jamb
> > > > > Location:
> > > > > > > > (setq p3 (getpoint p1 "\nSelect Approximate Strike Or
> Jamb
> > > > > > Location:
> > > > > > > > (setq dsz 26)
> > > > > > > > (setq os (/ dsz 2))
> > > > > > > > (setq an1 (angle p1 p3))
> > > > > > > > (setq p4 (polar p1 an1 os))
> > > > > > > > (setq an2 (angle p1 hg))
> > > > > > > > (setq p5 (polar p1 an2 os))
> > > > > > > > (setq dst (distance p1 p2))
> > > > > > > > (setq an3 (angle p1 p2))
> > > > > > > > (setq p6 (polar p5 an3 dst))
> > > > > > > > (setq p7 (polar p6 an1 dsz))
> > > > > > > > (setq dst2 (/ dst 2))
> > > > > > > > (setq p8 (polar p5 an3 dst2))
> > > > > > > > (setq p9 (polar p4 an3 dst2))
> > > > > > > > (command "break" p4 p5 "break" p7 p6 "line" p4 p7 ""
> > "line"
> > > p5
> > > > > p6
> > > > > > > > (ssget "f" (list p8 p9))
> > > > > > > > ) ;end AC20.lsp
> > (defun AC20 (drsz / CHS pt1 pt2 pt3 pt5 pt6 pt7 p1 p2 p3
> > os an1 an2 an3 dst dst2 dsz dis osm en1 en2)
> > (setvar "osmode" 0)
> > (initget "C M")
> > (if (not CHS)
> > (setq CHS "C"))
> > (setq temp (getkword (strcat "\nInsert Door At The Corner Or Midpoint
Of
> > (if temp
> > (setq chs temp))
> > (if (= chs "C")
> > (progn
> > (setq pt2 (getpoint pt1 "\nSelect Approximate Strike Or Jamb
> > Location:"))
> > (setq pt3 (getpoint pt1 "\nSelect Outside Face To Be Opened: "))
> > (setq ost 3)
> > (princ ost)
> > ;;(setq drsz 26)
> > (command "break" pt5 pt4 "break" pt7 pt6 "line" pt5 pt7 "")
> > (command "line" pt4 pt6 "")
> > ;;(ssget "w" pt4 pt7))
> > (if (= chs "M")
> > (progn
> > (setq p1 (getpoint "\nSelect Intersection/Midpoint: "))
> > (setq p2 (getpoint p1 "\nSelect Outside Face To Be Opened: "))
> > (setq hg (getpoint p1 "\nSelect Approximate Hing Or Jamb Location:
> > (setq p3 (getpoint p1 "\nSelect Approximate Strike Or Jamb
> > Location:"))
> > ;;(setq dsz 26)
> > (setq os (/ dsz 2))
> > (command "break" p4 p5 "break" p7 p6 "line" p4 p7 "")
> > (command "line" p5 p6 "")
> > ;;(ssget "f" (list p8 p9))
> > (list en1 en2)
> > ) ;end AC20.lsp
