Answered this question years ago, pick 1st line, pick perp to second line and then dim all crossing lines. No idea what I called it. Will try to find again.
Found 1 not quite what you want. Will look for others.
; dim multi offsets
; By AlanH Nov 2021
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/line-up-dimension-text-in-multiple-dimensions/td-p/10739193
; (defun c:dimoffs ( / pt1 pt2 pt3 ent ent1 ss obj1 obj2 tpos lst oldsnap oldaunits )
(defun c:dimoffs ( /)
(if (not (tblsearch "dimstyle" "Standard"))
(alert "The correct dimstyle is not available \nResults may not be what is expected")
(command "dimstyle" "R" "Standard")
(setq oldsnap (getvar 'osmode))
; left or right by lee-mac
(defun lM:ISL-R (ent pnt / cpt der )
(setq pnt (trans pnt 1 0))
(setq cpt (vlax-curve-getclosestpointto ent pnt)
der (vlax-curve-getfirstderiv ent (vlax-curve-getparamatpoint ent cpt))
(if (minusp (sin (- (angle cpt pnt) (angle '(0.0 0.0) der))))
(setq dir 1.0)
(setq dir -1.0)
(princ)
(defun alg-ang (object pnt)
(angle '(0. 0. 0.)
obj
object
pnt
(setq oldaunits (getvar 'aunits))
(setvar 'aunits 3)
(setq pi2 (/ pi 2.0))
(setq ent (entsel "\nPick control line " ))
(setq entname (car ent))
(setq pt1 (cadr ent))
(setq pt1 (vlax-curve-getclosestpointto (vlax-ename->vla-object (car ent)) pt1))
(setq ent1 (entget (car ent)))
(setvar 'osmode 0)
(setq pt2 (getpoint "\nPick a point on left side"))
(setq pt3 (getpoint pt2 "\nPick a point on right side "))
(setq ss (ssget "F" (list pt2 pt3)))
(setq ss (ssdel (cdr (assoc -1 ent1)) ss)) ; remove control
(setq ang (angle pt2 pt3))
(setvar 'osmode 0)
(command "line" pt2 pt3 "")
(setq obj1 (vlax-ename->vla-object (entlast)))
(setq lst '() )
(repeat (setq x (sslength ss))
(setq entl (ssname ss (setq x (- x 1))))
(setq obj2 (vlax-ename->vla-object (ssname ss x)))
(setq intpt (vlax-invoke obj2 'intersectWith obj1 acExtendnone))
(LM:ISL-R (car ent) intpt)
(setq lst (cons (list (* (distance intpt pt1) dir) intpt entL) lst))
(setq lst (vl-sort lst '(lambda (x y) (< (car x)(car y)))))
(vla-delete obj1)
(setq pt (cadr (nth 0 lst)))
(setq obj (vlax-ename->vla-object ( caddr (nth 0 lst))))
(setq ang (alg-ang obj pt))
(setq len (distance pt1 pt3))
(setq x -1)
(setq pt3 (polar pt1 (+ ang pi2) len))
(repeat (length lst)
(setq obj2 (vlax-ename->vla-object (caddr (nth (setq x (1+ x)) lst))))
(setq pt2 (vlax-curve-getclosestpointto obj2 pt1))
(setq dist (distance pt1 pt2) )
(if (< (car (nth x lst)) 0.0)(setq dist (- 0.0 dist)))
(Command "Dim" "align" pt1 pt2 pt3 (rtos dist 2 2) "exit")
(setq pt3 (polar pt3 ang 2.5))
(setq obj2 (vlax-ename->vla-object (entlast)))
(vlax-put obj2 'TextPosition pt3)
(setvar 'osmode oldsnap)
(setvar 'aunits oldaunits)
(princ)
(c:dimoffs)
Closer to what you want.
; dim multi offsets ver3
; By AlanH Jan 2022
(defun c:dimoffs3 ( / )
(setvar 'aunits 3)
(setq pt1 (getpoint "\nPick a point on left side "))
(setq pt2 (getpoint pt1 "\nPick a point on other side of last line "))
(setvar 'dimse1 1)
(setvar 'dimse2 1)
(setvar 'osmode 0)
(setq ss (ssget "F" (list pt1 pt2)))
(command "line" pt1 pt2 "")
(setq lst '())
(setq obj2 (vlax-ename->vla-object (ssname ss (setq x (1- x)))))
(setq intpt (vlax-curve-getclosestpointto obj2 pt1))
(setq lst (cons (list (distance intpt pt1) intpt) lst))
(vla-delete obj1)
(setq ang (angle pt1 (nth 1 (nth 0 lst))))
(setq x 0)
(repeat (- (length lst) 1)
(Command "Dim" "align" (cadr (nth x lst)) (cadr (nth (1+ x) lst)) (cadr (nth x lst)) "" "exit")
(setq x (1+ x))
(setvar 'dimse1 0)
(setvar 'dimse2 0)
(princ)
(c:dimoffs3)
Just drag a line over all the desired lines pt1 -> pt2.
