How to write in short form for conditions
avinash00002002
avinash00002002
Hi
I have a conditions like below
(if (and (= ang 40) (= angt 4))
(setq bmark 20)
(if (and (= ang 40) (= angt 5))
(setq bmark 20)
(if (and (= ang 45) (= angt 4))
(setq bmark 23)
(if (and (= ang 43) (= angt 4))
(setq bmark 23)
(if (and (= ang 45) (= angt 5))
(setq bmark 23)
(if (and (= ang 45) (= angt 6))
(setq bmark 25)
(if (and (= ang 45) (= angt 7))
(progn (setq bmark 23)
(setq angtold angt)
(setq angt 4)
(if (and (= ang 45) (= angt 8))
(setq angtold angt)
(setq angt 5)
ang = angle section
angt = anglt thickness
bmark = backmark
any suggestion.
Avinash
annoisscary
I usually go for cond() in these types of situations as you don't need to worry about throwing in a progn when the condition is met and you need to do lots of stuff. Also I feel like it is just a little more readable and a little less code bloat when having do many conditions.
(cond
		(setq bmark 20)
		(and (= and 40) (= angt 5))
		(setq bmark 20)
		(setq bmark 23)
		(setq bmark 23)
		(setq bmark 23)
		(setq bmark 25)
		(setq bmark 23)
		(setq angtold angt)
		(setq angt 4)
		(setq bmark 23)
		(setq angtold angt)
		(setq angt 5)
You could also consider grouping the conditions that will end up with the same result
(cond
		(setq bmark 20)
		(setq bmark 20)
		(or
		(setq bmark 23)
		(setq bmark 25)
		(setq bmark 23)
		(setq angtold angt)
		(setq angt 4)
		(setq bmark 23)
		(setq angtold angt)
		(setq angt 5)
Honestly, not 100% certain the syntax of the or is correct right now, its super early and I cant be bothered to test atm.
komondormrex
hey,
other one
(setq bmark
	(cond
		((or (and (= ang 40) (= angt 4))
			20
		((or (and (= ang 45) (= angt 4))
			 (and
				  (setq angtold angt)
				  (setq angt 4)
			 (and
				  (setq angtold angt)
				  (setq angt 5)
			23
		((and (= ang 45) (= angt 6))
			25
john.uhden
@annoisscary ,
I really didn't check all those conditions, but your structure looks fine.
Never seen "atm" before but I take it that it means "at this moment" not "automated teller machine."
John F. Uhden
