Re-associating Block attribute fields with selected block
patrick_johannes96EREGF
Hi All,
I'm looking to see if a lisp routine that allows you to select a block you want to update the attributes of and then select the source block for it to read the information from.
I have currently been working on a block that contains information for a manhole (Block 1),
and then another block which reads the attributes in the block 1 and updates the block in the table (Block 2).
At the moment when i copy both Block 1 & 2 at the same time and update the information in block 1 the information in block 2 will update. The issue comes when you copy block 1 independently of block 2 and they are no longer linked.
is a lisp the right way to fix this issue or is there another method to link the information between the two blocks?
I have attached the dwg with the blocks in, the  blocks at the bottom are not linked.
Thanks in advance!
ВeekeeCZ
Agree that this method of maintaining a pair of blocks is very cumbersome.
Personally, I would rather create a routine that selects a group of blocks 1, and creates a table 2.
The question is probably up to you as to how much of a benefit it is to have that linked by field. Think about what types of editing you do, how often, whether there is some benefit. From my point of view, I would simply delete the original table and create a new one within 5 seconds.
