Replace an old block with a new one with the same name
DGaither
DGaither
I have a block named DSBDSHTM that is used for creating sheet metal cut lists. I recently needed to add a new attribute (Part#) to this block. The new block is the same name as the original. I am trying to find a way that I can go into a drawing that has the old block definition in it and globally update all the existing blocks with the new one and have the attributes refreshed. I need those to remain on their same layers & in their same position in the drawing. To date I have been unable to find any utility or Lisp that can do this automatically. Does anyone know of such a utility or Lisp code that will work? Thanks in advance for any help.
I am using AutoCAD 2020 with mainly Autolisp but VisualLisp code would be ok as well.
DGaither
I was able to make a Lisp that accomplishes what I was needing. Thanks all!
paullimapa
Would you be willing to share that lisp routine with the community by posting it here?
Paul Li
IT Specialist
@The Office
DGaither
No problem, it really turned out to be simple function. It is for a specific named block (dsbdshtm).
(defun upd-shtm-block ( / #INS)
(setq #INS (getvar "lastpoint"))
(if (tblsearch "block" "dsbdshtm")
(command "_.insert" "dsbdshtm=" nil)
(command "attsync" "n" "dsbdshtm")
(princ)
);defun upd-shtm-block
