- Mute
- Permalink
- Report
Greetings, Community.
The VLA-Rotate method requires an object, base point, and an angle.
How would you use the VLA-Rotate method with a selection set?
Is there an easy way to convert a selection set to an object?
The selection set was created using code by Wold and Puckett:
https://www.cadtutor.net/forum/topic/56008-select-copy-of-an-object-after-copy-command/
Thank you for your time and attention. I look forward to your replies.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
CAD Administrator
