Wuauw, thanks a lot! just had to add a () with entlast. Also added this code to set stil of Mtext line spacing style to exact:
(setq zeilenab 2) ;; or whatever you like
(if (assoc 73 ent)
(entmod (subst (cons 73 zeilenab)(assoc 73 ent) ent))
(entmod (append ent (list (cons 73 zeilenab))))
About the
function pads a numeric string with apostrophe
i don't really know where i have to put it in my lisp, bevor or after my command "mtext". And do i have to change the code, because my Value is setq ctext?
My code looks like this now:
(setq delta_m (- reun_mb_x liun_mb_x)) ; dargestellte Koord.diff im Modellb.
(setq delta_a (- reun_af_x liun_af_x)) ; dargestellte Koord.diff im Ansichtsf.
(setq cy_af liun_af_y)
(if (and (> alpha (/ pi 2.)) (< alpha (* 3 (/ pi 2.)))) ; Richtg. der Linie in Abh. von Drehung MB in AF
(setq richtg (- alpha (/ pi 2.)))
(setq richtg (+ alpha (/ pi 2.)))
) ; end if
(if (< richtg 0) (setq richtg (+ richtg pi pi))) ; nur Richtung 0 .. 2pi zulässig
(if (> richtg (* 2 pi)) (setq richtg (- richtg pi pi)))
(setq textht 2)
(if (< richtg (/ pi 2)) ; Textrichtg. in Abh. von Linienrichtg.
(progn (setq textri (/ (* richtg 180 ) pi))
(setq textausri "ur")
) ; end progn
(progn (setq textri (/ (* (- richtg pi) 180 ) pi))
) ; end progn
) ; end if
(setq cx_mb startx)
(setq minx (min liun_mb_x reun_mb_x)) ; es kann auch in negativer Richtung verlaufen
(setq maxx (max liun_mb_x reun_mb_x))
(while (<= cx_mb minx) ; ersten auf Rand im MB vorh. Wert ermitteln
(setq cx_mb (+ cx_mb delta_l))
) ; end while cx_mb
(while (< cx_mb maxx)
(setq delta_m1 (- cx_mb liun_mb_x)) ; Streckenverhältnisse
(setq cx_af (+ liun_af_x (* (/ delta_m1 delta_m) delta_a)))
(setq ctext (rtos cx_mb 2 0))
(setq p1 (list cx_af cy_af))
(setq p2 (polar p1 richtg 15))
(command "mtext" p2 "a" textausri "d" p1 p2 "h" textht "" ctext "")
(vlax-put (vlax-ename->vla-object (entlast)) 'backgroundfill 1)
(setq ent (entget (entlast)))
(setq offset 1.2) ;; or whatever you like
(if (assoc 45 ent)
(entmod (subst (cons 45 offset)(assoc 45 ent) ent))
(entmod (append ent (list (cons 45 offset))))
(if (assoc 73 ent)
(command "linie" p1 p2 "")
) ; end while cx_mb
Thanks a lot for your help, really apreciate it!
