How to stop a commands in a script file
Finally I managed to stop all the commands in script file: -INSERT "BLOCK A=C:\SCRIPTS\BLOCK B" 0,0,0 ERASE (SETQ en (ENTLAST)) QSAVE
john.vellek
Hi @Anonymous,
You might also try using (SSGET "L") instead of the Entlast. Both should work however, I notice that you set a variable "en" to the last entity but don't do anything with it. If you are trying to erase "EN" you should define it before the erase command.
(setq EN (entlast))
Erase
!en
Thanks for your contribution.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
ВeekeeCZ
Try attached script (erase .txt).
INSERT
"BLOCK A=C:\SCRIPTS\BLOCK B.dwg"
S
1
R
0
0,0
ERASE
l
QSAVE
Actually I'm not trying to erase anything. I'm just trying to replace a block with another and not just one drawing but 3000. So I made a script and somehow it always stuck after replacing the block. It needed an "Esc" or a "Cancel". These terms are not known in scr, so I searched for something else. Then I found a lisp in which ERASE (SETQ en (ENTLAST)) was used. Adding this to my simple block replacing script did the trick for the batch job (BatchScript). Please modify and reply if you want. AI_SELALL REPTEXT PLC 1 PLC 3 AI_SELALL REPTEXT PLC 2 PLC 4 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; INZOOMEN ZOOM E ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; IO BLOK VERVANGEN -INSERT "IO_BLOCK_1=C:\SCRIPTS\Scripts\IO_BLOCK_2" 0,0,0 ERASE (SETQ en (ENTLAST)) QSAVE
