DCL Error Trap Help
DCL Error Trap Help
Jonathan3891
Advisor Advisor
Message 1 of 11
DCL Error Trap Help
Jonathan3891
My lisp runs as it should, but I get "error: quit / exit abort" after its finished.
Can someone with more experience help me out?
Thanks!
;Modify Z Elevation
;by Jonathan Norton
(defun c:modz (/ dcl_id ) (if(not Elv) (setq Elv "0.00") ) (setq flag 4) (setq dcl_id (load_dialog "ModZ.dcl")) (while (> flag 2) (if (not (new_dialog "ModZ" dcl_id)) (exit) ) (set_tile "Elv" Elv) (action_tile "Elv" "(setq Elv $value)") (action_tile "Accept" "(saveVars)(done_dialog 1)") (action_tile "Pick" "(saveVars)(done_dialog 4)") (action_tile "Cancel" "(done_dialog 0)(setq Elv nil)") (setq flag (start_dialog)) (if (= flag 1) (progn (setq ssi (ssget "X")) (unload_dialog dcl_id) (command "_.CHANGE" ssi "" "_P" "_E" Elv "") (princ(strcat "Object(s) Elevation set to " Elv)) ) ) (if (= flag 4) (progn (setq ss (ssget)) (unload_dialog dcl_id) (command "_.CHANGE" ss "" "_P" "_E" Elv "") (princ(strcat "Object(s) Elevation set to " Elv)) ) ) ) (princ) );defun (defun saveVars(/ Elv) (setq Elv(distof(get_tile "Elv"))) ) (princ)
ModZ : dialog {
label = "Modify Z";
	: edit_box
	label = "Elevation:";
	key = "Elv";
	alignment = left;
	edit_limit = 20;
	edit_width = 20;
	: row {
		: spacer { height = 1; }
		:row {
	: button {
	label = "ALL";
	key = "Accept";
	alignment = centered;
	width = 12;
	is_default = true;
	allow_accept = true;
	mnemonic = "A";
		: button {
	label = "PICK";
	key = "Pick";
	width = 12;
	is_default = true;
	mnemonic = "P";
	: button {
	label = "CANCEL";
	key = "Cancel";
	width = 12;
	is_default = false;
	is_cancel = true;
	mnemonic = "C";
Jonathan Norton
Blog | Linkedin
Replies (10)
Message 2 of 11
paullimapa
Looks like you've programmed a while loop:
(while (> flag 2)
But you've unloaded the dialog when you select Pick:
    (if (= flag 4)
      (progn
	(setq ss (ssget))
 Then the routine will loop back to the top & attempt to load the dialog again but it's no longer loaded:
    (exit)
That's why you're getting the (exit) error message.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 3 of 11
Jonathan3891
Can you show me how to fix it please?
Jonathan Norton
Blog | Linkedin
Message 4 of 11
paullimapa
Just don't unload the dcl when you select Pick:
    (if (= flag 4)
      (progn
	(setq ss (ssget))
; place a semicolon to not execute this code	(unload_dialog dcl_id)
Paul Li
IT Specialist
@The Office
Message 5 of 11
Jonathan3891
I want the dialog to unload.
Jonathan Norton
Blog | Linkedin
Message 6 of 11
paullimapa
If you want the dialog to unload then why create the while loop?
Just remove that completely from the code to eliminate the error message:
;Modify Z Elevation
;by Jonathan Norton
(defun c:modz (/ dcl_id ) (if(not Elv) (setq Elv "0.00") ) (setq flag 4) (setq dcl_id (load_dialog "ModZ.dcl")) ;
; no need for while loop
; (while (> flag 2)
; (if (not (new_dialog "ModZ" dcl_id)) (exit) ) (set_tile "Elv" Elv) (action_tile "Elv" "(setq Elv $value)") (action_tile "Accept" "(saveVars)(done_dialog 1)") (action_tile "Pick" "(saveVars)(done_dialog 4)") (action_tile "Cancel" "(done_dialog 0)(setq Elv nil)") (setq flag (start_dialog)) (if (= flag 1) (progn (setq ssi (ssget "X")) (unload_dialog dcl_id) (command "_.CHANGE" ssi "" "_P" "_E" Elv "") (princ(strcat "Object(s) Elevation set to " Elv)) ) ) (if (= flag 4) (progn (setq ss (ssget)) (unload_dialog dcl_id) (command "_.CHANGE" ss "" "_P" "_E" Elv "") (princ(strcat "Object(s) Elevation set to " Elv)) ) ) ;
; don't execute this closing bracket to while loop
; ) ; (princ) );defun (defun saveVars(/ Elv) (setq Elv(distof(get_tile "Elv"))) ) (princ)
Paul Li
IT Specialist
@The Office
Message 7 of 11
Jonathan3891
Its in there because I was following the Afralisp guide on hiding dialog boxes. I'm trying to learn DCL.
What makes the DCL hide to make a selection?
Thanks for your help!
Jonathan Norton
Blog | Linkedin
Message 8 of 11
paullimapa
You can always execute (unload_dialog dcl_id) code at the very end without including it inside your (if (= flag test which does not hide the dialog
Paul Li
IT Specialist
@The Office
Message 9 of 11
scot-65
(if (= flag 4)
(progn
(setq ss (ssget))
(unload_dialog dcl_id) <<<<<<<<<<<<< (setq flag 0)
Rewrite this to set the flag so it can escape the while loop.
Then, after closing the while loop, unload the dialog.
);while
Also, protect the user input!
(if (setq ss (ssget))...
Do not underestimate the ingenuity of complete fools.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 10 of 11
salman_majgaonkar
ModZ : dialog { label = "Modify Z";
: edit_box { label = "Elevation:"; key = "Elv"; alignment = left; edit_limit = 20; edit_width = 20;}
: row {
: spacer { height = 1; }}
:row {
: button { label = "ALL"; key = "Accept"; alignment = centered; width = 12; is_default = true; allow_accept = true; mnemonic = "A";}
: button { label = "PICK"; key = "Pick"; alignment = centered; width = 12; is_default = true; allow_accept = true; mnemonic = "P";}
: button { label = "CANCEL"; key = "Cancel"; alignment = centered; width = 12; is_default = false; is_cancel = true; mnemonic = "C";} }
:row {
: button { label = "Front view"; key = "Pick1"; alignment = centered; width = 12; is_default = true; allow_accept = true; mnemonic = "F";}
: button { label = "Top view"; key = "Pick2"; alignment = centered; width = 12; is_default = true; allow_accept = true; mnemonic = "T";} } }
(defun c:modz()
(if (not Elv) (setq Elv 0))
(setq flag 4)
(if (not (new_dialog "ModZ" dcl_id)) (exit))
(set_tile "Elv" (rtos Elv 2 3))
(action_tile "Elv" "(saveVars)")
(action_tile "Accept" "(done_dialog)(setq ddiag 1)")
(action_tile "Pick" "(done_dialog)(setq ddiag 2)")
(action_tile "Pick1" "(done_dialog)(setq ddiag 3)")
(action_tile "Pick2" "(done_dialog)(setq ddiag 4)")
(action_tile "Cancel"  "(setq ddiag 0)")
(start_dialog) (unload_dialog dcl_id)
(if (= ddiag 0) (progn (setq Elv nil) ))
(if (= ddiag 1) (progn
(setq ssi (ssget "X")) (if ssi (progn
(command "-view" "o" "t")
(princ (strcat "Object(s) Elevation set to " (rtos Elv 2 3) "\n")) )) ))
(if (= ddiag 2) (progn
(acet-error-init (list (list "cmdecho" 0) nil))
(setq ss (ssget)) (if ss (progn
(acet-error-restore) )) ))
(if (= ddiag 3) (progn
(command "-view" "o" "f") (c:modz)))
(if (= ddiag 4) (progn
(command "-view" "o" "t") (c:modz)))
(defun saveVars()
(setq Elv (atof (get_tile "Elv"))))
(princ)
Message 11 of 11
scot-65
Try this -
(start_dialog)
To:
(action_tile "Pick2" "(done_dialog 4)")
(setq ddiag (start_dialog))
Let's take advantage of done_dialog's integer return to the start_dialog.
Scot-65
