How to set the visstate of a dynamic block through a script - not through a lisp
timothy_crouse
timothy_crouse
Does anyone know of a command to set the visstate of a dynamic block through a script?
I can select the block as follows in the script:
SSX{enter}
{enter}
B
"block name with spaces"{enter}
{enter} ;; it may or may not appear as selected
this will prove it is selected
ERASE{enter}
PREVIOUS{enter}
Once selected is there any way to set the visstate through the script?
Or perhaps have the script run a lisp that sets the visstate.  I am interested in carrying this out via a script as it is to be part of an automation batch script
Thanks in Advance
-Tim C.
paullimapa
assuming you can run lisp then read up on this related thread
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/repeat-insert-dynamic-block-and-choo...
Paul Li
IT Specialist
@The Office
Sea-Haven
"Automation batch script" there is no problem in calling a lisp program in a script, so add the variables to the link lisp code when using in a script.
open dwg1
(load "mywindows")
(mywindows "window1" "Casement")
Close Y
randyorten7707
Community Visitor
Community Visitor
Setting the visibility state (VisState) of a dynamic block through a script can vary depending on the software you're using. If you're not using LISP, you might be working with a different scripting language or software environment.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
namespace DynamicBlockVisibility
public class Commands
[CommandMethod("SetVisState")]
public void SetVisibilityState()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
// Get the block name and visibility state from the user
PromptStringOptions opts = new PromptStringOptions("\nEnter the block name: ");
PromptResult res = ed.GetString(opts);
if (res.Status != PromptStatus.OK) return;
string blockName = res.StringResult;
opts.Message = "\nEnter the visibility state: ";
string visibilityState = res.StringResult;
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
if (bt != null && bt.Has(blockName))
ObjectId btrId = bt[blockName];
BlockTableRecord btr = tr.GetObject(btrId, OpenMode.ForWrite) as BlockTableRecord;
if (btr != null && btr.IsDynamicBlock)
foreach (ObjectId objId in btr)
if (objId.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(BlockReference))))
BlockReference blkRef = tr.GetObject(objId, OpenMode.ForWrite) as BlockReference;
if (blkRef != null && blkRef.IsDynamicBlock)
on the sublime by longinus
// Set the visibility state
blkRef.DynamicBlockReferencePropertyCollection.SetVisibilityState(visibilityState);
blkRef.RecordGraphicsModified(true);
tr.Commit();
