How to prevent if a system variable does not exist, Activex
carlos_m_gil_p
Message 1 of 9
carlos_m_gil_p
Hello boys how are you.
With the changes of versions of autocad, they are eliminating system variables.
How do I avoid the error, if a variable does not exist, with activex functions.
I tried as follows, but it didn't work.
(vl-catch-all-error-p
  (setq v (vlax-variant-value (vla-GetVariable (vla-get-activedocument (vlax-get-acad-object)) "casa"))))
 Thanks.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
Replies (8)
Message 2 of 9
_gile
Try this way:
  (vl-catch-all-apply
    '(lambda ()
Why not simply use the getvar function?
  (vl-catch-all-apply
    '(lambda () (setq v (getvar "casa")))
Gilles Chanteau
GileCAD
GitHub
Message 3 of 9
carlos_m_gil_p
Hi @_gile , thank you for your answer.
I always apply it with getvar.
The point is that I wanted to learn how to do it with vl ...
Thank you.
Greetings.
AutoCAD 2026
Message 4 of 9
john.uhden
Often times the vl way is the long way.
Another thing I was reminded of last week...
The vla-item method errors out if the named item doesn't exist.  You would think it would return nil, but it doesn't.  So if you are looking for the existence of a table entry, use the old tblsearch function instead.
John F. Uhden
Message 5 of 9
Sea-Haven
Why not
(if (setq v (getvar 'casa))
(progn do something now
Message 6 of 9
carlos_m_gil_p
Hi @john.uhden , how are you?
I understand that the vl are more powerful.
Yes, it is a longer way, but I think it can be solved by creating a general function for each case.
I am starting to use VSCode and with one click I can insert these functions.
I improve my code and my workflow.
All this based on my opinion and in the same way learn more about the vl functions.
Thanks for the information about the vla-item method, I will keep it in mind for future use.
Greetings.
Hi @Sea-Haven
I am not saying that it is wrong or that I do not use them that way, as I mentioned above, it is a matter of learning more about these functions.
Thanks.
AutoCAD 2026
Message 7 of 9
_gile
;; gc:GetItem (gile)
;; Returns the vla-object of item if it exists in the collection (or nil)
;; Arguments
;; col : collection (vla-object)
;; name : object name (string) or index (integer)
(defun gc:GetItem (col name / obj)
  (vl-catch-all-apply
    (function (lambda () (setq obj (vla-Item col name))))
  obj
Gilles Chanteau
GileCAD
GitHub
Message 8 of 9
Sea-Haven
Have a look at attached
Message 9 of 9
carlos_m_gil_p
Hello @Sea-Haven , thank you very much for your information and help.
Greetings.
AutoCAD 2026
