Dialog box not by .DCL files
devitg
Advisor Advisor
Message 1 of 8
devitg
Hi all. In the last few months ago ,  a poster show and upload some  LISP  defun that BUILD by it self a DCL LIKE dialog box .
It can receive a layers names list as argument , and then user can select it
Please route me where I can get it.
Thanks in advance.
Accepted solutions (3)
Replies (7)
Message 2 of 8
_gile
Here's a example:
;; ListBox (gile)
;; Dialog box to make one ore many choices in a list
;; Arguments
;; title : title of the dialog (string)
;; msg : message (string), "" or nil for none
;; keylab : associative list of key label ((key1 . label1) (key2 . label2) ...)
;; flag : 0 = popup list
;;        1 = single choice list
;;        2 = multiple choices list
;; Return : key of the option (flag = 0 or 1) or the list of keys (flag = 2)
;; Using example
;; (listbox "Layouts" "Choose a layout" (mapcar 'cons (layoutlist) (layoutlist)) 1)
(defun ListBox (title msg keylab flag / str2lst tmp file dcl_id choice)
  (defun str2lst (str sep / pos)
    (if	(setq pos (vl-string-search sep str))
      (cons (substr str 1 pos)
	    (str2lst (substr str (+ (strlen sep) pos 1)) sep)
      (list str)
  (setq	tmp  (vl-filename-mktemp "tmp.dcl")
	file (open tmp "w")
  (write-line
    (strcat "ListBox:dialog{label=\"" title "\";")
    file
  (if (and msg (/= msg ""))
    (write-line (strcat ":text{label=\"" msg "\";}") file)
  (write-line
    (cond
      ((= 0 flag) "spacer;:popup_list{key=\"lst\";")
      ((= 1 flag) "spacer;:list_box{key=\"lst\";")
      (T "spacer;:list_box{key=\"lst\";multiple_select=true;")
    file
  (write-line "}spacer;ok_cancel;}" file)
  (close file)
  (setq dcl_id (load_dialog tmp))
  (if (not (new_dialog "ListBox" dcl_id))
    (exit)
  (start_list "lst")
  (mapcar 'add_list (mapcar 'cdr keylab))
  (end_list)
  (action_tile
    "accept"
    "(or (= (get_tile \"lst\") \"\")
    (if (= 2 flag) (progn
    (foreach n (str2lst (get_tile \"lst\") \" \")
    (setq choice (cons (nth (atoi n) (mapcar 'car keylab)) choice)))
    (setq choice (reverse choice)))
    (setq choice (nth (atoi (get_tile \"lst\")) (mapcar 'car keylab)))))
    (done_dialog)"
  (start_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete tmp)
  choice
You can find some more examples on this page:
http://gilecad.azurewebsites.net/LISP/Dialog.lsp
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
_gile
Here's the translated 'GetLayer' dialog from the upper link
;; GETLAYERS (gile) 02/12/07
;; Returns the list of the checked layers in the dialog box
;; arguments
;; title : title of the dialog box or nil (default = Choose the layers)
;; lst1 : list of the pre-checked layers or nil
;; lst2 : list of the unable layers (greyed out) or nil
(defun getlayers (title	   lst1	    lst2     /	      sublist
		  toggle_column	    tmp	     file     lay      layers
		  len	   dcl_id   lst
  (defun sublist (lst start leng / n r)
    (if	(or (not leng) (< (- (length lst) start) leng))
      (setq leng (- (length lst) start))
    (setq n (+ start leng))
    (repeat leng
      (setq r (cons (nth (setq n (1- n)) lst) r))
  (defun toggle_column (lst)
    (apply 'strcat
	   (mapcar
	     (function
	       (lambda (x)
		 (strcat ":toggle{key="
			 (vl-prin1-to-string x)
			 ";label="
	     lst
	file (open tmp "w")
  (while (setq lay (tblnext "LAYER" (not lay)))
    (setq layers (cons (cdr (assoc 2 lay)) layers))
  (setq	layers (vl-sort layers '<)
	len    (length layers)
  (write-line
    (strcat
      "GetLayers:dialog{label="
      (cond (title (vl-prin1-to-string title))
	    ("\"Choose the layers\"")
      ";:boxed_row{:column{"
      (cond
	((< len 12) (toggle_column layers))
	((< len 24)
	 (strcat (toggle_column (sublist layers 0 (/ len 2)))
		 "}:column{"
		 (toggle_column (sublist layers (/ len 2) nil))
	((< len 45)
	 (strcat (toggle_column (sublist layers 0 (/ len 3)))
		 "}:column{"
		 (toggle_column (sublist layers (/ len 3) (/ len 3)))
		 "}:column{"
		 (toggle_column (sublist layers (* (/ len 3) 2) nil))
	(T
	 (strcat (toggle_column (sublist layers 0 (/ len 4)))
		 "}:column{"
		 (toggle_column (sublist layers (/ len 4) (/ len 4)))
		 "}:column{"
		 (toggle_column (sublist layers (/ len 2) (/ len 4)))
		 "}:column{"
		 (toggle_column (sublist layers (* (/ len 4) 3) nil))
      "}}spacer;ok_cancel;}"
    file
  (close file)
  (if (not (new_dialog "GetLayers" dcl_id))
    (exit)
  (foreach n lst1
    (set_tile n "1")
  (foreach n lst2
    (mode_tile n 1)
  (action_tile
    "accept"
    "(setq lst nil)
    (foreach n layers
    (if (= (get_tile n) \"1\")
    (setq lst (cons n lst))))
    (done_dialog)"
  (start_dialog)
  lst
Gilles Chanteau
GileCAD
GitHub
Message 4 of 8
hak_vz
Try this
;; List Box  -  Lee Mac
;; Displays a DCL list box allowing the user to make a selection from the supplied data.
;; msg - [str] Dialog label
;; lst - [lst] List of strings to display
;; bit - [int] 1=allow multiple; 2=return indexes
;; Returns: [lst] List of selected items/indexes, else nil
(defun LM:listbox ( msg lst bit / dch des tmp rtn )
    (cond
        (   (not
                (and
                    (setq tmp (vl-filename-mktemp nil nil ".dcl"))
                    (setq des (open tmp "w"))
                    (write-line
                        (strcat "listbox:dialog{label=\"" msg "\";spacer;:list_box{key=\"list\";multiple_select="
                            (if (= 1 (logand 1 bit)) "true" "false") ";width=50;height=15;}spacer;ok_cancel;}"
                        des
                    (not (close des))
                    (< 0 (setq dch (load_dialog tmp)))
                    (new_dialog "listbox" dch)
            (prompt "\nError Loading List Box Dialog.")
        (   t
            (start_list "list")
            (foreach itm lst (add_list itm))
            (end_list)
            (setq rtn (set_tile "list" "0"))
            (action_tile "list" "(setq rtn $value)")
            (setq rtn
                (if (= 1 (start_dialog))
                    (if (= 2 (logand 2 bit))
                        (read (strcat "(" rtn ")"))
                        (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")")))
    (if (< 0 dch)
        (unload_dialog dch)
    (if (and tmp (setq tmp (findfile tmp)))
    rtn
(defun select_layers ( / layer_collection layerlist)
(setq layer_collection(vla-get-Layers(vla-get-ActiveDocument(vlax-get-acad-object))))
(vlax-for item layer_collection (setq layerlist (cons (vlax-get item 'Name) layerlist)))
(LM:listbox "Layers:"  (reverse layerlist) 1)
(setq sel (select_layers))
Miljenko Hatlak
Message 5 of 8
devitg
@_gile  I will test it . Thanks
Message 6 of 8
Sea-Haven
If you have less than say 25 layers can use this also, it will make a dcl with radio buttons. There are 4 versions available Multi Radio Buttons, multi getvals, multi toggles and Multi getvals image, the simplest download location is Cadtutor\downloads. Else email info@alanh.com.au and will send all back to you.
The code needed
(setq lst (list of layers))
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(setq ans (ah:butts but "V"  lst)) ; in this case returns layer name.
Message 7 of 8
devitg
@Sea-Haven , Hi , it is what I was looking for .
Message 8 of 8
Sea-Haven
Glad to help. RLX has some nice library DCL's as well.
This is the two columns choice
; Multi ah:button Dialog box for 2 columns choice replacement of initget
; By Alan H Feb 2021 info@alanh.com.au
; It will remember what ah:button ws pressed if ran again with same request.
; (if (not ah:buttscol)(load "Multi radio buttons 2col.lsp")); loads the program if not loaded already
; (if (not ah:but)(setq ah:but 1)) 			            	; this is needed to set default ah:button
; (if (not ah:but2)(setq ah:but2 1))							; you can reset default ah:button to user pick
; just use "but" value and compare to a list
; if you want  a number use (atof (nth ah:but ah:butlst) or (atoi (nth ah:but2 ah:butlst2)
; (if (not ah:buttscol)(load "Multi Radio buttons 2col.lsp"))
; (if (= ah:but nil)(setq ah:but 1))
; (if (= ah:but2 nil)(setq ah:but2 1))
; (setq lst (list "Select angle" "2 pts" "45" "90" "180" "225" "270" "315" ))
; (setq lst2 (list "Select type" "Rotate" "Label" "Marker" "Both"))
; (ah:buttscol ah:but ah:but2 "Rotate point" lst lst2)
;(if (= ah:2col nil)(setq ah:2col 1))
;(if (= ah:2col2 nil)(setq ah:2col2 1))
;(setq lst (list "Select number" "1" "2" "3" "4" "5" "6" "7" "8" "9" "10"))
;(setq lst2 (list "Select Char" "A" "B" "C" "D"))
;(ah:buttscol ah:2col ah:2col2 "Please choose" lst lst2)
;(setq ans1 (nth ah:2col ah:butlst))
;(setq ans2 (nth ah:2col2 ah:butlst2))
;(ah:buttscol ah:but ah:but2 "please choose" '("Yes or No" "Yes" "No") '("up" "down") )
(defun col1 ( / l)
(setq x 1)
(repeat (length ah:butlst)
    (setq l (strcat "1Rb" (rtos x 2 0)))
    (if  (= (get_tile l) "1" )
        (setq ah:col1 x)
    (setq x (+ x 1))
(princ)
(defun col2 ( / j )
    (setq x 1)
        (setq j (strcat "2Rb" (rtos x 2 0)))
        (if  (= (get_tile j) "1" )
            (setq ah:col2 x)
        (setq x (+ x 1))
	(princ)
(defun ah:buttscol (ahdef1 ahdef2  toplabel ah:butlst ah:butlst2 / fo fname x  k )
(setq len1 (length ah:butlst) len2 (length ah:butlst2))
; do wid1 wid2 next version
(setq fo (open (setq fname "d:\\acadtemp\\test.dcl") "w"))
;(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
(write-line  "AHbuttscol : dialog 	{" fo)
(write-line  (strcat " label = " (chr 34) toplabel (chr 34) ";" ) fo)
(write-line "	: row	{" fo)
(write-line "	: boxed_radio_column 	{" fo)
(write-line  (strcat " width = 24  ;")  fo)
(setq x 1)
(write-line  (strcat " label = " (chr 34) (nth 0 ah:butlst) (chr 34) " ;" )fo)
(repeat (- (length ah:butlst) 1)
    (write-line "	: radio_button	{" fo)
    (write-line  (strcat "key = "  (chr 34) "1Rb" (rtos  x  2 0)  (chr 34) ";") fo)
    (write-line  (strcat "label = " (chr 34) (nth x  ah:butlst) (chr 34) ";") fo)
    (write-line "	}" fo)
    (write-line "spacer_1 ;" fo)
    (setq x (+ x 1))
(if (< len1 len2)
    (repeat (- len2 len1)
(setq x 1)
(write-line  (strcat "	label = " (chr 34) (nth 0 ah:butlst2) (chr 34) " ;" )fo)
(repeat (- (length ah:butlst2) 1)
    (write-line  (strcat "key = "  (chr 34) "2Rb" (rtos x  2 0)  (chr 34) ";") fo)
    (write-line  (strcat "label = " (chr 34) (nth x  ah:butlst2) (chr 34) ";") fo)
    (setq x (+ x 1))
(if (< len2 len1)
    (repeat  (- len1 len2)
(write-line "	ok_cancel ;" fo)
(close fo)
(setq dcl_id (load_dialog fname))
(if (not (new_dialog "AHbuttscol" dcl_id) )
    (exit)
(setq x 1)
    (setq k (strcat "1Rb" (rtos x 2 0)))
    (action_tile k  (strcat "(setq ah:2col "  (rtos x 2 0) ")" ))
    (if (= ahdef1 x)(set_tile k "1"))
    (setq x (+ x 1))
(setq x 1)
(repeat (- (length ah:butlst2)1)
    (setq k (strcat "2Rb" (rtos x 2 0)))
    (action_tile k  (strcat "(setq ah:2col2 "  (rtos x 2 0) ")" ))
    (if (= ahdef2 x)(set_tile k "1"))
    (setq x (+ x 1))
(action_tile "accept"  "(col1) (col2) (done_dialog)")
(action_tile "cancel" "(done_dialog) (exit)")
(start_dialog)
(vl-file-delete fname)
(princ)
) ; end defun
