How to get total length of multiple dynamic blocks with different width?
georg_holter
georg_holter
If i have many ident dynamic blocks (with different dynamic length (=Distance1) and width (=Distance2)) - is there any possibility to get this result:
" -> Total length of dynamic Blocks with width *width (f.example 0.3)* :
-> Total length of dynamic Blocks with width *width (f.example 0.1)* :
-> Total length of dynamic Blocks with width *width (f.example 0.4)* : " and so forth....
see also the attached pic!
This Lisp is nearly there i have to get to (BIG THANKS TO @ВeekeeCZ) :
(vl-load-com)
(defun c:Test
       (/ total selectionset count intger selectionsetname obj)
  (defun LM:getdynpropvalue ( blk prp )
    (setq prp (strcase prp))
    (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value)))
	     (vlax-invoke blk 'getdynamicblockproperties)
  (if (setq total 0
	    selectionset
	     (ssget '((0 . "INSERT")
		      (-4 . "<or")
		      (2 . "`*U*")
		      (2 . "_P1000")
		      (-4 . "or>")
    (progn
      (setq count (sslength selectionset))
      (repeat (setq intger (sslength selectionset))
	(setq selectionsetname
	       (ssname selectionset
		       (setq intger (1- intger))
	      obj (vlax-ename->vla-object selectionsetname)
	      total (+ total
		       (LM:getdynpropvalue obj "Distance1")
      (alert (strcat " Total number of Dynamic Blocks :"
		     (itoa count)
		     "\n"
		     " Total lengths of Dynamic Blocks :"
		     (rtos total 2)
    (princ)
  (princ)
The PERFECTNESS would be to choose optional output results in CSV.
please help me!
that would be awesome!
THANK YOU VERY MUCH!!!!!
ВeekeeCZ
The code is not really mine, so just quickly.
If you need a csv, just a search for it, plenty of examples. I'm sure you'll figure.
Good luck.
(vl-load-com)
(defun c:ListP1000 ( / s i e d w l a)
  (if (setq s (ssget '((0 . "INSERT") (2 . "`*U*,_P1000"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i))))
      (if (and (not (vl-catch-all-error-p (setq d (vl-catch-all-apply 'getpropertyvalue (list e "AcDbDynBlockPropertyDistance1")))))
	       (not (vl-catch-all-error-p (setq w (vl-catch-all-apply 'getpropertyvalue (list e "AcDbDynBlockPropertyDistance2")))))
	       (setq w (rtos w))
	(setq l (if (setq a (assoc w l))
		  (subst (cons w (+ d (cdr a))) a l)
		  (cons (cons w d) l))))))
  (alert (princ (apply 'strcat (mapcar '(lambda (x) (strcat "\nTotal length of w" (car x) ": " (rtos (cdr x)))) l))))
  (princ)
georg_holter
Thank you (AGAIN) !!! You`re THE MAN!!!!!! my head is spinning again.... 😄
AND: you're right! i'm sorry...i think the Original code is from @Anonymous ! THANK YOU!!
aaron_gonzalez
here is a little modificaction, you can drop the length of the dynamic block in the block
(vl-load-com)
(defun c:Test
  (if (setq total 0
    selectionset
      (-4 . "<or")
      (2 . "`*U*")
      (2 . "_P1000")
      (-4 . "or>")
    (progn
      total (+ total
(setq lon-total (apply '+ ld-list))
(setq nombre (getstring T "\nIngrese un nombre: "))
(setq xyz (getpoint "Press the mouse button: ")) ;obtiene posicion del puntero-raton
(command "_.color" "bylayer")
(command "_.text" "ML" xyz 1 0 (strcat "L :" (rtos total 2 0 ) " m, " nombre " , " (itoa count) " tramos " ) ) ;; Formato y prescicion
(command "_.color" "BYLAYER")
    (princ)
  (princ)
