Difference by display style
saitoib
saitoib
Hi all.
rectang 0,0 100,100
rectang 100,0 200,100
After creating the above
With the display style as 2D wireframe, execute the following Lsip and select each square
Two entities are selected for each.
If you change the display style to concept, execute test, and select each square
only one entity is selected.
Why is this?
Thank you.
(defun c:test ( / ent pts ss nn i id)
  (setq ent (entget (car (entsel))))
  (setq pts (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) ent)))
  (setq ss (ssget "CP" pts))
  (princ "\n")
  (princ (setq nn (sslength ss)))
  (setq i 0)
  (repeat nn
    (princ "\n")
    (princ (ssname ss i))
    (setq i (1+ i))
  (princ)
Saitoib
cadffm
Also if you select the secend (the right) rectangle? 😉
CP (and w c cw ..) are view-dependend object selection methods
and the visualstyle is part of the current view,
also ZOOM and PAN can change the result of your TEST!
2DWireframe(CPU)  works different to all other VisualStyles(GPU),
what you stumbled over is how it works.
EDIT::
>>" and select each square only one entity is selected."
Not on my side: The last drawn rectangle select both rectangles, but the left one just the left.
view-dependend object selection methods are nothing what you can trust.
Sebastian
saitoib
@cadffm
I would say that the basis for drawing is a 2D wireframe.
I understand.
Thank you very much.
Saitoib
