- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
If i have many ident dynamic blocks (with different dynamic length (=Distance1) and width (=Distance2)) - is there any possibility to get this result:
" -> Total length of dynamic Blocks with width *width (f.example 0.3)* :
-> Total length of dynamic Blocks with width *width (f.example 0.1)* :
-> Total length of dynamic Blocks with width *width (f.example 0.4)* : " and so forth....
see also the attached pic!
This Lisp is nearly there i have to get to (BIG THANKS TO @ВeekeeCZ) :
(vl-load-com) (defun c:Test (/ total selectionset count intger selectionsetname obj) (defun LM:getdynpropvalue ( blk prp ) (setq prp (strcase prp)) (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value))) (vlax-invoke blk 'getdynamicblockproperties) ) ) (if (setq total 0 selectionset (ssget '((0 . "INSERT") (-4 . "<or") (2 . "`*U*") (2 . "_P1000") (-4 . "or>") ) ) ) (progn (setq count (sslength selectionset)) (repeat (setq intger (sslength selectionset)) (setq selectionsetname (ssname selectionset (setq intger (1- intger)) ) obj (vlax-ename->vla-object selectionsetname) total (+ total (LM:getdynpropvalue obj "Distance1") ))) (alert (strcat " Total number of Dynamic Blocks :" "< " (itoa count) " >" "\n" " Total lengths of Dynamic Blocks :" "< " (rtos total 2) " >" ) ) ) (princ) ) (princ) )
The PERFECTNESS would be to choose optional output results in CSV.
please help me!
that would be awesome!
THANK YOU VERY MUCH!!!!!
