How to get Page Number of a PDFunderlay element with Autolisp ?
Kh.mbkh
Message 1 of 11
Kh.mbkh
How to get Page Number of a PDFunderlay element with Autolisp ?, since this is the "key" variable to access a wanted PDFunderlay.
Thanks !
Accepted solutions (3)
Replies (10)
Message 2 of 11
paullimapa
(getpropertyvalue (car(entsel)) "DefinitionId/ItemName")
Paul Li
IT Specialist
@The Office
Message 3 of 11
paullimapa
and another method:
(vla-get-itemname (vlax-ename->vla-object (car(entsel))))
Paul Li
IT Specialist
@The Office
Message 4 of 11
ronjonp
And another:
(cdr (assoc 2 (entget (cdr (assoc 340 (entget (car (entsel))))))))
Message 5 of 11
Kh.mbkh
Thnaks @paullimapa @ronjonp .
Is there any documentation for PDFunderlay with Autolisp. (How to unload, detach ... )
Message 6 of 11
cadffm
The same like for other objects.
DXF Reference - Underlay / PDFunderlay
ActiveX ObjectModel - PdfUnderlay
nothing more
Or is there a documentation about "how to create a Line"? No.
Creation
DXF/AUTOLISP: ENTMAKE  -> PDFunderlay is not supported
ActiveX -> vla-addPdfUnderlay doesn't exist  -> PDFunderlay creation is not supported, as documented about the PdfUnderlay object.
Sebastian
Message 7 of 11
Kh.mbkh
Ok thanks @cadffm , so how to simply "unload" and "Reload" a PDFunderlay (as an entity got with (car (entsel))) with Autolisp ?
Message 8 of 11
cadffm
since there are no explicit function to do that, also no native autocad command,
I would need to check all the data structure to understand, how it works.
I am not next to my  Autocad and my own codes and notes,
so I would need to search online for it
but it's on you.
Start to check all around the pdfunderlay definition
(setq dictcoll (vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object))))
(vlax-for di dictcoll
(if
(eq (vl-catch-all-apply 'vla-get-name (list di)) "ACAD_PDFDEFINITIONS")
(Vlax-dump-object di)
Please check the code yourself, I am walking on a treadmill with a 6" device, isn t funny to read&write.
Sebastian
Message 9 of 11
paullimapa
I could be mistaken but I don't see a method to unload, reload or even detach a specific pdf using lisp.
This means we have to rely on the External References Palette to do this.
There's only a lisp function to delete all pdfs...see the following links for examples:
https://forums.augi.com/archive/index.php/t-131322.html
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-detach-all-pdfs/td-p/8852704...
https://www.cadtutor.net/forum/topic/71943-change-from-delete-to-remove-path-pdf/
Paul Li
IT Specialist
@The Office
Message 10 of 11
Kh.mbkh
Yeah @paullimapa All we find is about detach the PDFunderlay (so delete it). I think we'll be obliged "again" to switch to .NET 😶
Message 11 of 11
paullimapa
here's a .NET version to unload all pdfs:
https://adndevblog.typepad.com/autocad/2016/07/unload-all-the-pdf-underlay.html
Paul Li
IT Specialist
@The Office
