Lisp to detach all pdfs
mpa-la
mpa-la
Hello, I would like a lisp that detaches all pdfs.  The closest I could find is below.  (For credit, I found at https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-detach-all-images-and-underl... Could someone edit it so that it only does pdfs, not xrefs and images?  I don't know enough lisp to do so.  Thanks!  Allison
(defun c:detachall ( / mspcoll dictcoll)
(vl-load-com)
(vl-cmdf "_.-xref" "D" "*")
(vl-cmdf "_.-image" "D" "*")
(setq mspcoll (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(vlax-for ent mspcoll
(if
(or
(eq (vl-catch-all-apply 'vla-get-objectname (list ent)) "AcDbDwfReference")
(eq (vl-catch-all-apply 'vla-get-objectname (list ent)) "AcDbPdfReference")
(eq (vl-catch-all-apply 'vla-get-objectname (list ent)) "AcDbDgnReference")
(eq (vl-catch-all-apply 'vla-get-objectname (list ent)) "AcDbOle2Frame")
(vla-delete ent)
(setq dictcoll (vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object))))
(vlax-for di dictcoll
(if
(or
(eq (vl-catch-all-apply 'vla-get-name (list di)) "ACAD_IMAGE_DICT")
(eq (vl-catch-all-apply 'vla-get-name (list di)) "ACAD_PDFDEFINITIONS")
(eq (vl-catch-all-apply 'vla-get-name (list di)) "ACAD_DGNDEFINITIONS")
(eq (vl-catch-all-apply 'vla-get-name (list di)) "ACAD_DWFDEFINITIONS")
(progn
(vlax-for d di
(vla-delete d)
(vla-delete di)
(vl-cmdf "_.externalreferences")
(princ)
Moshe-A
@mpa-la  hi,
give this a try.
enjoy
moshe
(vl-load-com)
; detach pdf underlay (defun c:delpdf (/ ss tbl dict) (if (setq ss (ssget "_X" '((0 . "PDFUNDERLAY")))) (progn (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (setq tbl (tblsearch "layer" (cdr (assoc '8 (entget ename))))) (if (not (= (logand (cdr (assoc '70 tbl)) 4) 4)) ; skip locked layers (entdel ename) ) ); foreach (setq dict (vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object)))) (vlax-map-collection (vla-item dict "ACAD_PDFDEFINITIONS") 'vla-delete) (vlax-release-object dict) ); progn ); if (princ) ); c:delpdf
mpa-la
Perfect, thanks so much!!
ronjonp
This should work too .. although you'll onlys ee the changes upon next open. Not sure of ramifications so use at our own risk 😉
(if (setq e (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_PDFDEFINITIONS"))))
  (entdel e)
