Message 1 of 20
I've been searching for this lisp for awhile and just found it on another thread. Can someone help me to modify it?
Lisp works well as it is, the only changes i a want to make are:
- An option to WINDOW or select ALL
- Insert a table location. Something like this: (defun insert_table (lst pct / tab row col ht i n space)
- If 2 is too complicated i'd be happy with 1 option
;| http://www.cadtutor.net/forum/showthread.php?83991-Populate-Table Original by Oleg Fateev Modified by hms 2014/11/14 as a 'demo' to JCprog http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extract-attributes-from-a-specific-block-and-write-to-table/m-p/5399759#U5399759 |; (defun C:CLIST (/ a1 a2 a3 acapp acsp adoc atable attdata atts col headers pt row title) (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object)))) ) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))) ) (vlax-for blk (vla-get-blocks adoc) (if (= (vla-get-IsXref blk) :vlax-true) (vlax-for x blk (if (and (= (vla-get-ObjectName x) "AcDbBlockReference") (wcmatch (vla-get-EffectiveName x) "*|blk01") ) (progn (setq atts (vlax-invoke x 'getattributes)) (foreach att atts (cond ((wcmatch (vla-get-tagstring att) "tag01") (setq a1 (vla-get-textstring att)) ) ((wcmatch (vla-get-tagstring att) "tag02") (setq a2 (vla-get-textstring att)) ) ((wcmatch (vla-get-tagstring att) "tag03") (setq a3 (vla-get-textstring att)) ) ) ) (setq attdata (cons (list a1 a2 a3) attdata)) ) ) ) ) ) (if (setq pt (getpoint "\nSpecify table location:")) (progn (setq atable (vla-addtable acsp (vlax-3d-point pt) (+ 2 (length attdata)) 3 (/ (getvar 'dimtxt) 2) (* (getvar 'dimtxt) 4) ) ) (vla-put-regeneratetablesuppressed atable :vlax-true) (setq col 0) (foreach wid (list 10.0 10.0) (vla-setcolumnwidth atable col wid) (setq col (1+ col)) ) (vla-put-horzcellmargin atable 0.3) (vla-put-vertcellmargin atable 0.3) (vla-setTextheight atable 1 2.0) (vla-setTextheight atable 2 1.4) (vla-setTextheight atable 4 1.4) (setq title "Demo") (vla-setText atable 0 0 title) (vla-setcelltextheight atable 0 0 2.0) (vla-SetCellAlignment atable 0 0 acMiddleCenter) (setq headers (list "Tag01" "Tag02" "Tag03")) (setq row 1 col 0 ) (repeat (length headers) (vla-SetCellAlignment atable row col acMiddleCenter) (vla-setcelltextheight atable row col 1.4) (vla-setText atable row col (car headers)) (setq headers (cdr headers)) (setq col (1+ col)) ) (setq row 2) (foreach record attdata (setq col 0) (foreach item record (vla-setText atable row col item) (vla-SetCellAlignment atable row col acMiddleCenter) (vla-setcelltextheight atable row col 1.4) (setq col (1+ col)) ) (setq row (1+ row)) ) (vla-put-regeneratetablesuppressed atable :vlax-false) (vla-put-height atable (+ (* (vla-get-rows atable) 2.2) 4.1)) (vla-update atable) ) ) (princ) ) (prompt "\n\t---\tStart command with CLIST\t---\n") (prin1) (or (vl-load-com)) (princ)
