Extraction to a Table Help
3arizona
Message 1 of 20
3arizona
 I've been searching for this lisp for awhile and just found it on another thread. Can someone help me to modify it?
Lisp works well as it is, the only changes i a want to make are:
  1. An option to WINDOW or select ALL
  2. Insert a table location.  Something like this: (defun insert_table (lst pct / tab row col ht i n space)
  3. If 2 is too complicated i'd be happy with 1 option
  4. ;| http://www.cadtutor.net/forum/showthread.php?83991-Populate-Table
     Original by Oleg Fateev
     Modified by hms 2014/11/14
     as a 'demo' to JCprog
     http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extract-attributes-from-a-specific-block-and-write-to-table/m-p/5399759#U5399759
    (defun C:CLIST (/ a1 a2 a3 acapp acsp adoc atable attdata atts col headers pt row title)
      (or adoc
          (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object))))
      (or acsp
          (setq acsp (vla-get-block (vla-get-activelayout adoc)))
      (vlax-for blk (vla-get-blocks adoc)
        (if (= (vla-get-IsXref blk) :vlax-true)
          (vlax-for x blk
            (if (and (= (vla-get-ObjectName x) "AcDbBlockReference")
                     (wcmatch (vla-get-EffectiveName x) "*|blk01")
              (progn
                (setq atts (vlax-invoke x 'getattributes))
                (foreach att atts
                  (cond ((wcmatch (vla-get-tagstring att) "tag01")
                         (setq a1 (vla-get-textstring att))
                        ((wcmatch (vla-get-tagstring att) "tag02")
                         (setq a2 (vla-get-textstring att))
                        ((wcmatch (vla-get-tagstring att) "tag03")
                         (setq a3 (vla-get-textstring att))
                (setq attdata (cons (list a1 a2 a3) attdata))
      (if (setq pt (getpoint "\nSpecify table location:"))
        (progn
          (setq atable
                 (vla-addtable
                   acsp
                   (vlax-3d-point pt)
                   (+ 2 (length attdata))
                   3
                   (/ (getvar 'dimtxt) 2)
                   (* (getvar 'dimtxt) 4)
          (vla-put-regeneratetablesuppressed atable :vlax-true)
          (setq col 0)
          (foreach wid (list 10.0 10.0)
            (vla-setcolumnwidth atable col wid)
            (setq col (1+ col))
          (vla-put-horzcellmargin atable 0.3)
          (vla-put-vertcellmargin atable 0.3)
          (vla-setTextheight atable 1 2.0)
          (vla-setTextheight atable 2 1.4)
          (vla-setTextheight atable 4 1.4)
          (setq title "Demo")
          (vla-setText atable 0 0 title)
          (vla-setcelltextheight atable 0 0 2.0)
          (vla-SetCellAlignment atable 0 0 acMiddleCenter)
          (setq headers (list "Tag01" "Tag02" "Tag03"))
          (setq row 1
                col 0
          (repeat (length headers)
            (vla-SetCellAlignment atable row col acMiddleCenter)
            (vla-setcelltextheight atable row col 1.4)
            (vla-setText atable row col (car headers))
            (setq headers (cdr headers))
            (setq col (1+ col))
          (setq row 2)
          (foreach record attdata
            (setq col 0)
            (foreach item record
              (vla-setText atable row col item)
              (setq col (1+ col))
            (setq row (1+ row))
          (vla-put-regeneratetablesuppressed atable :vlax-false)
          (vla-put-height atable (+ (* (vla-get-rows atable) 2.2) 4.1))
          (vla-update atable)
      (princ)
    (prompt "\n\t---\tStart command with CLIST\t---\n")
    (prin1)
    (or (vl-load-com))
    (princ)
Replies (19)
Message 2 of 20
Moshe-A
@3arizona  hi,
post a sample dwg so we can run this lisp.
moshe
Message 3 of 20
3arizona
moshe,
Sorry it too so long to reply.  I copied the tag so that i can post the drawing and now i cant get the lisp to extract anything.  Lisp only works on my original drawing and it's too big to post.  i've tried to save-as and remove all line work also copy and paste to a new drawing without any luck.  Attached is a copy of the tag drawing and maybe you or someone else can help me figure this out.
I though i had finally found the lisp i was looking for.
Message 4 of 20
devitg
Please show us, it.
Message 5 of 20
devitg
Please , clear it.
the block it is not an Xref
It give :vlax-false
Message 6 of 20
Moshe-A
@3arizona  hi,
the lisp you found does not do what you want, instead i suggest you to explore DATAEXTRACTION command.
moshe
Message 7 of 20
3arizona
devitg,
"Clear it" does it equal delete? :  (= (vla-get-IsXref blk) :vlax-true)
If i delete this line i get a syntax error.
sorry, not too proficient with lisps
Message 8 of 20
devitg
Find attached the way I get to work
The original LISP , is from my very good FRIEND . Oleg Fateev , sad to say he passed away a few years ago .
He honour me at the  cadtutor
https://www.cadtutor.net/forum/topic/48890-rectangle-lisplittle-help/page/2/?tab=comments#comment-40...
See he show my country flag , when the Football world champion at Russia
He teach me a  about 50 % of my lisp proficience {
Message 9 of 20
3arizona
Is there a way to change from selecting ALL to window a few objects?
Thank you very much and sorry to hear bout your friend. He's still helping others!!
Message 10 of 20
devitg
Please upload your DWG .
When one do not want , two can not do.
Put some from you .
Last time you put only one block
This lisp look for all the blockreference named  blk01.
Message 11 of 20
3arizona
Sorry, lisp works perfect!!!  At the moment lisp is searching entire drawing. i want an option to window a portion of the drawing or select all
Message 12 of 20
devitg
Or send me to my email. it is myusernamehere at gmail.com
Message 13 of 20
3arizona
it's the same drawing i posted with the tag.  I want to be able to select 1 or 2 tags
Message 14 of 20
devitg
Sorry, no pain , no gain,
Message 15 of 20
3arizona
hmsilva,
Can you help me finish this lisp? i believe your familiar with it.  I want to be able to select/window a portion of the blocks not ALL, as it currently does.
thank you all for your time.
Message 16 of 20
Sea-Haven
This may be usefull it uses a block in  layouts but could be changed to a selection but is a complete example of multi blocks to table.
Message 17 of 20
3arizona
Can someone can help me change this lisp provided by DEVITG? At the moment lisp is selecting ALL blocks and i want to WINDOW a few of them. I've tried a few thing that i know but cant figure i out.
modified by
;; Design by Gabo CALOS DE VIT from CORDOBA ARGENTINA
;;;    Copyleft 1995-2019 by Gabriel Calos De Vit ; DEVITG@GMAIL.COM
In honor  to by BIG FRIEND Oleg Fateev , aka OLD HORSE , from Saint Petersburg Russia
Sad to say he passed away a few years ago
  (or adoc
  (or acsp
;;;(setq blk (vlax-ename->vla-object (car (entsel))))
;;;(setq x blk)
;;;  (setq attdata nil)
    (if blk
      (vlax-for x blk
                 (wcmatch (vla-get-EffectiveName x) "*blk01");;  *blk01 instead *|blk01
          (progn
            (setq att (nth 0 atts))
            (foreach att atts
              (cond ((wcmatch (vla-get-tagstring att) "TAG01")
                    ((wcmatch (vla-get-tagstring att) "TAG02")
                    ((wcmatch (vla-get-tagstring att) "TAG03")
      );vlax-for
    ); if blok
  ); vlax-for blk at blk collection
    (progn
      (setq atable
             (vla-addtable
               acsp
               (vlax-3d-point pt)
               3
      (setq col 0)
        (setq col (1+ col))
      (setq title "Demo")
      (setq row 1
            col 0
        (setq col (1+ col))
      (setq row 2)
        (setq col 0)
          (setq col (1+ col))
        (setq row (1+ row))
      (vla-update atable)
  (princ)
(prin1)
(or (vl-load-com))
(princ)
Message 18 of 20
hmsilva
Modified...
 Modified by hms 2019/06/26
 as a 'demo' to 3arizona
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extraction-to-a-table-help/m-p/8852571#M386385
		attdata	      atts   col    headers	  i	 pt
		row    ss     title  x
  (or adoc
  (or acsp
  (prompt "\nSelect blocks blk01 to make a Table:  ")
  (if
    (setq ss (ssget (list '(0 . "insert") '(66 . 1) (cons 2 "*blk01,`*U*"))))
     (repeat (setq i (sslength ss))
       (setq x (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
       (if (wcmatch (vla-get-EffectiveName x) "*blk01")
	 (progn
	   (foreach att	atts
    (progn
      (setq atable
	     (vla-addtable
	       acsp
	       (vlax-3d-point pt)
	       3
      (setq col 0)
	(setq col (1+ col))
      (setq title "Demo")
      (setq row	1
	    col	0
	(setq col (1+ col))
      (setq row 2)
	(setq col 0)
	  (setq col (1+ col))
	(setq row (1+ row))
      (vla-update atable)
  (princ)
(prin1)
(or (vl-load-com))
(princ)
Hope this helps,
Henrique
Message 19 of 20
3arizona
 hmsilva,
Works Perfect!!!!!!  Thank you all for your help and time
Message 20 of 20
hmsilva
@3arizona wrote:
 hmsilva,
You're welcome, 3arizona
Glad I could help
Henrique
