How to force running commands in the created drawing ?
y.awwad
Message 1 of 8
y.awwad
I created a new drawing using ( vla-add )
The code creates a point in the created drawing but ( zoom extents ) in the original drawing not the created drawing  .. anyone can help in this ?
(defun C:DRZ (/ acadApp acadDoc)
  (vl-load-com)
  (setq acadApp (vlax-get-acad-object))
  (setq acadDoc (vla-Add (vla-get-Documents acadApp)))
  (vla-AddPoint (vla-get-ModelSpace acadDoc) (vlax-3d-point 10000 10000 0))
  (vla-put-ActiveDocument acadApp acadDoc)
  (vla-ZoomExtents acadApp)
  (vla-Activate acadDoc)
  (vla-SendCommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "Zoom" " " "e" " "))
  (princ)
(princ)
Replies (7)
Message 2 of 8
ec-cad
; Try changing:
; To be:
(vla-SendCommand acadDoc (strcat "Zoom" " " "e" " "))
ECCAD
Message 3 of 8
y.awwad
@ec-cad
Same issue .. The code created a point in the created drawing but ( zoom extents ) in the original drawing not the created drawing
Message 4 of 8
komondormrex
@y.awwad
try this one. you cannot zoom extents a point if pdmode is set to 0.
  (vl-load-com)
  (vla-postcommand acadDoc "pdmode 3 ")
  (vla-postcommand acadDoc "point 10000,10000,0 ")
  (vla-postCommand acadDoc "Zoom e ")
  (princ)
Message 5 of 8
y.awwad
@komondormrex
Thanks for replying , I tried the code .. it keeps loading till i select the original drawing and click anywhere ( when i return back to created drawing i found it zoomed extents ) but i have to select the original drawing and left click anywhere 1st to stop hanging , Do you have a solution for this ?
Message 6 of 8
ВeekeeCZ
Last time I was fighting the same issue ended up with using acaddoc.lsp.
https://forums.autodesk.com/t5/civil-3d-customization/vla-sendcommand-issue/m-p/12251272#M24275
Message 7 of 8
y.awwad
@ВeekeeCZ
Strange that Autodesk didn't put an option to do so 🤦‍
Message 8 of 8
komondormrex
triple <Esc>.
but you should to look at odbx.
