lisp code to Get Cursor Position
GeryKnee
GeryKnee
Ηello everyone.
the following returns the currnt Cursor position
(defun fnCursorPoint ( / result)
(while(not(setq result (cadr (grread T 0 0))))
(setq result nil))
result
But if there is no mouse movement. it does not return, running inside the while loop, as grread waits for an event to be released from llop and return the cursor position.
I need if possible (if autolisp supports it), using autolisp another code that will return the current cursor position.
Gery.
paullimapa
Not sure it can be done in lisp without cursor movement but check out Lee Macs version
https://www.lee-mac.com/grtext.html
Paul Li
IT Specialist
@The Office
komondormrex
@GeryKnee
hey,
check the following
(while t (print (cadr (grread t 1 0))))
move cursor or not, left click to get cursor coordinates.
(defun fncursorpoint (/ grread_data)
	(while (not (= 3 (car (setq grread_data (grread t 1 0))))))
  	(cadr grread_data)
