How to define a Lisp prefix
gustavosanmartin
gustavosanmartin
Hello, does anyone know how I can define a prefix in the Lisp (Prefix "L=") that they have hung. Thanks in advance.
(defun creadim (altura /)
(setq
Dim_Name "Estilo_Cotas"
DIMBLK-Name "Oblique" ;archtick ClosedFilled
dimscale 1.0
quote_scale 1 ;scala di quota
Arrow_Size 0.05
Center_Mark_Size 0.0625
Decimal_Places 2
Dimension_Line_Spacing 0.0
Extension_Above_Dimension_Line 0.0
Extension_Line_Origin_Offset 0.0
Gap_From_dimension_Line_to_Text 0.0
Tolerance_Decimal_places 2
Text_Movement 0
Text_Font "SIMPLEX.SHX"
Text_Height altura
(command "_-style" "Estilo_Cotas" "SIMPLEX.SHX" "0" "1" "" "" "" "")
;(setvar "lunits" 2)
;(setvar "DIMASSOC" 1)
(setq ds
(list
(cons 0 "DIMSTYLE")
(cons 1 "L= ")
(cons 100 "AcDbSymbolTableRecord")
(cons 100 "AcDbDimStyleTableRecord")
(cons 2 Dim_Name) ;Dim style name
(cons 70 0) ; Standard flag
(cons 3 " [m]"); DIMPOST
(cons 4 ""); DIMAPOST
(cons 5 DIMBLK-Name) ;DIMBLK-Name of block instead of default arrowhead
(cons 6 DIMBLK-Name);(cons 6 "ClosedFilled"); DIMBLK1
(cons 7 "");(cons 7 DIMBLK-Name); DIMBLK2
(cons 170 0) ;DIMALT-turns off alternate units
(cons 40 dimscale) ;DIMSCALE-sets the overall scale factor applied to all dimensions
(cons 41 Arrow_Size) ;DIMASZ-sets the size of the arrow/tick
(cons 42 Extension_Line_Origin_Offset); DIMEXO
(cons 43 Dimension_Line_Spacing); DIMDLI
(cons 44 Extension_Above_Dimension_Line) ;DIMEXE-specifies how far to extend the extention line beyound the dim line
(cons 45 0.0); DIMRND
(cons 46 0) ;DIMDLE-sets the distance the dimension line extends beyond the extension line
(cons 47 0.0); DIMTP
(cons 48 0.0); DIMTM
(cons 71 0); DIMTOL
(cons 72 0); DIMLIM
(cons 73 0) ;DIMTIH-controls the position of dimension text inside extention lines ;METTE IL TESTO DI QUOTA ORIZZONTALE
(cons 74 0) ;DIMTOH-controls the position of dimension text outside extention lines
(cons 75 1); DIMSE1 ;1 sopprime la linea di estensione, 0 la lascia
(cons 76 1); DIMSE2 ;1 sopprime la linea di estensione, 0 la lascia
(cons 77 1) ;DIMTAD-controls the vertical position of text in relation to the dim line
(cons 78 3) ;DIMZIN-controls the suppression of zeros
(cons 79 1); DIMAZIN
(cons 140 Text_Height) ;DIMTXT-specifies the height of the text in the dim
(cons 141 Center_Mark_Size); DIMCEN
(cons 142 0.0); DIMTSZ
(cons 143 0.5) ;DIMALTF-controls the scale factor for alt. units
(cons 144 quote_scale); DIMLFAC ;scala di quota
(cons 145 0.0); DIMTVP
(cons 146 0.64); DIMTFAC
(cons 147 Gap_From_dimension_Line_to_Text) ;DIMGAP-sets the distance from around the dim text
(cons 170 0); DIMALT
(cons 171 2) ;DIMALTD-controls the decimal places for units
(cons 172 0) ;DIMTOFL-forces a line inside extension lines
(cons 173 1); DIMSAH
(cons 174 0); DIMTIX
(cons 175 0); DIMSOXD
(cons 176 256); DIMCLRD
(cons 177 256); DIMCLRE
(cons 178 256); DIMCRRT
(cons 179 0); DIMADEC
(cons 270 2) ;DIMUNIT-sets the units format for all dims ;2 decimale ; 4architettonico
(cons 271 Decimal_Places) ;DIMDEC-sets the number of decimal places of primary units
(cons 272 Tolerance_Decimal_places); DIMTDEC
(cons 273 2) ;DIMALTU-sets the units for alt. units
(cons 275 0) ;DIMAUNIT-sets the angular format for angular dims
(cons 276 1); DIMFRAC
(cons 277 2); DIMLUNIT ;2 decimale ; 4architettonico
(cons 278 0); DIMDSEP
(cons 279 Text_Movement); DIMTMOVE
(cons 280 0) ;DIMJUST-controls the horizontal positioning of dim text
(cons 281 -1); DIMSD1
(cons 282 -1); DIMSD2
(cons 283 1); DIMTOLJ
(cons 284 3); DIMTZIN
(cons 285 1); DIMALTZ
(cons 286 0) ;DIMALTTZ-Toggles the suppression in tolerance values
;(cons 287 0); DIMFIT
;(cons 288 0); DIMUPT
;(cons 289 0); DIMATFIT
(cons 340 (tblobjname "style" "Estilo_Cotas")); DIMTXSTY
;(cons 341 (cdr (assoc 330 (entget (tblobjname "block" "."))))); DIMLDRBLK
;(cons 342 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK
;(cons 343 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK1
;(cons 344 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK2
;(cons 371 -2); DIMLWD
;(cons 372 -2); DIMLWE
(entmake ds)
(command "_-dimstyle" "_restore" dim_name)
;(dimsave)
(princ)
(defun dimsave ()
(command "DIMSTYLE" "_R" "DIMTEST")
(setvar "DIMTXSTY" "Estilo_Cotas")
(command "DIMSTYLE" "_S" "DIMTEST" "Y")
ВeekeeCZ
Use this line
(cons 3 "L=<>[m]"); DIMPOST
gustavosanmartin
Thank you so much. It is the perfect solution.
pbejse
I see it too, hung indeed
