Hello. I am not sure if it is possible to change the base point for a block, but not for all instances of the same block. For example, if I have a block named "BOX", and in my drawing I have 50 instances of this block, is it possible for half of them the base point to be in the centre of the block and for half of them to be on the edge of the block? I am aware of @lee Mac lisp routine (http://www.lee-mac.com/lisp/html/ChangeBlockBasePointV1-5.html) but this does the trick for all blocks with this specific name. Is there a way to do it just for the blocks that I select? If this is possible not sure if after that, the use of ATTSYNC command won't ruin the work. Would be easy to create 2 blocks with different base points, but what I need is to change this in the already existing drawings (and there are hundreds of the :)). Many thanks
