Lisp that copies Link Template to Object data
BriamR
BriamR
Hi Autodesk Community!
I would like to know if it is possible to copy or transfer the content of the link template of selected elements to a specific data object.
The selected objects can be polylines and hatches or blocks.
Below I show a graphic example of what I would like to know if it is possible.
In the following image I have selected a graphic element made up of polyline and hatch drawing; the Object Data and Link Template have the same name SDM_DEM_DEMARCACION
And in this last graphic example that I show I have the drawing of a selected block which has the Object Data and Link Template with the same name SDM_SEN_SENALIZACION
I have researched in the autodesk forums, but I still can't get anything accurate to what I post in this post.
https://forums.autodesk.com/t5/autocad-map-3d-forum/transfer-link-template-data-to-object-data/td-p/...
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/tblsearch-link-template/m-p/2041898#...
Thanks in advance for your help time.
BriamR
Theme update: The Geotools tool https://thedesignsense.com/geo-tools/ has the GT_DB2OD command that says transfer database linked data (Link Template) to object data; the personal drawback is that it is licensed and not freely distributed.
I appreciate your attention and help in advance.
braudpat
Hello
Have you many Links to copy into OD ?
Because the "XDA" routine from Gilles (gile) let you copy the Xdata Info
and then you can paste the Info into a String OD Field ...
But it is ONE BY ONE object and ONE BY ONE XData Info ...
The "XDA" routine comes from this interesting Topic :
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/programs-for-xdata/td-p/10423416
The Health, Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
BriamR
Hi @braudpat , thank you very much for answering this post; Regarding "Have you many Links to copy into OD?", I tell you that in most cases there are always a considerable amount of Database Linked Data (Link Template) that I must transfer to the Object Data, that is, I must recover that information en masse because it is large volume of drawing.
Note: "XD" is a great routine, but in this case I would not know how to use it for this case, I tried it and could not understand it to apply it in terms of transferring Database Linked Data (Link Template) to Object Data.
Greetings, and thanks in advance for your contribution.
BriamR
Update topic: Annex to the post .dwg and .mdb files examples of what I want to do in a routine (lisp), I appreciate your help in advance.
kyrojas2696
Hi! @BriamR It is important that if you get a solution for your question, you share it, thank you. I could apply your case to optimize some of my work processes. greetings to all
