How to create automatic layouts
適用対象外
43,526件の閲覧回数
116件の返信
メッセージ1/117
適用対象外
Hi Everyone,
Please help me to create automatic layouts for the attached drawing
Also request you to please provide me the LISP/FAS file.
The attache dwg is simple drawing. But i have 200 grids in some cases.
Please help on this.
Thank you in advance.
0 件のいいね
解決済み
43,527件の閲覧回数
116件の返信
返信 (116)
メッセージ21/117
ronjonp
That's quite the program!
I was only referring to the sample sheet the OP provided on tab 'X-XXX-X which is 11x17 paper size.
0 件のいいね
メッセージ22/117
適用対象外
Hello guys.
Where can i find the source? Still looking for a solution by witch the blocks in modelsapce are in a angel and in the layout the viewpor should stand stright up. Is that difficult to create?
Regards
0 件のいいね
メッセージ23/117
maratovich
Have you watched several of our posts before?
You ask what I described?
Maybe we can do it.
Give us an example of your .dwg file and an example of how it should work out.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
0 件のいいね
メッセージ24/117
適用対象外
Sorry did not read properly. But here is an example from a drawing.
The block has three attributes where the name('s) for the layout is given.
Regards Henk
0 件のいいね
メッセージ25/117
maratovich
You can only do this for flat rectangles. Rotated ones are not created.
An example of how to do the video. Names by the attribute of the block.
www.kdmsoft.net
0 件のいいね
メッセージ26/117
ronjonp
It would be much easier if your block was defined as a 1x1 unit square. Then the X an Y scale could be set to the sheet size. Also put the insertion point in the center of the box. From that you have all the information to make a view that matches.
0 件のいいね
メッセージ27/117
適用対象外
Thanx for the reply.
I will replace the insertpoint to teh center of the block.
The second thing is that the size off the viewport has the same size of the block. I only used the example drawing of the earlier post Trail2.dwg.
No need for a frame on the paperspace even the scale may be the same as in modelspace 1:1.
So only a paperspace whit a (rotated UCS) viewport would be nice.
Regards Henk
0 件のいいね
メッセージ28/117
適用対象外
And of course a new sample drawing
0 件のいいね
メッセージ29/117
vishwa0121
Thank you very much for your effort. its really useful but still i am facing some issues
1) i am facing trouble in Scaling factor.
2) and also title block is missing wen layout creates.
is it possible to modify as per above requirements?
Regards
vishwa
0 件のいいね
メッセージ30/117
dani_cs
Hello  lando7189,
I am very interested in a lisp like that. I tried it but I could not run it. My idea is to use blocks (they will be the Viewports of each layout) alligned to a line and when I run the lisp, it will make all layouts with the ucs of all blocks
Best regards,
Daniel.
0 件のいいね
メッセージ31/117
maratovich
There are several solutions. Watch the video.
Ask a specific question.
Add your example here.
www.kdmsoft.net
0 件のいいね
メッセージ32/117
dani_cs
Hello maratovich
I have been looking for a routine able to do this many time. I have a road axis and 188 blocks (viewports) allign to it by the mid point. But making all layouts one by one it's a waste of time. So do you know a routine able to make all layouts automatically with the configuration of a template tab, and orientated to the respective UCS viewport?
Look at the example and I expect you understand my question.
Best regards,
Daniel.
0 件のいいね
メッセージ33/117
ronjonp
What scale are you working at? 01 >> Scale: 2.0691 >> Twist: 0.0 .. that is an odd scale
0 件のいいね
メッセージ34/117
ronjonp
See attached ... made from sample drawing. That drawing has an educational stamp BTW.
0 件のいいね
メッセージ35/117
dani_cs
Hello  rperez,
Yes I know it's a odd scale. I did it very quickly hehe
0 件のいいね
メッセージ36/117
dani_cs
 Hello rperez,
I dit it at home with educational autocad, yes.
I saw attached, and that's I am looking for. I think you used a lisp or another software, aren't you?
It would be perfect for me.
Best regards,
Daniel.
0 件のいいね
メッセージ37/117
ronjonp
If you refer to THIS post there is a code base to make these layouts. Then all you have to do is apply the logic from THIS post and you have a solution.
メッセージ38/117
dani_cs
I tried it many times and I could not run it. That's the reason I posted on here again. Thanks for your effort.
Regards.
0 件のいいね
メッセージ39/117
適用対象外
Hi
0 件のいいね
メッセージ40/117
maratovich
The decision will be in 2-3 days.
www.kdmsoft.net
0 件のいいね
