Lisp Xref VP Freeze In All Viewports Except Current
Edwin.Saez
Advisor Advisor
Edwin.Saez
Hello everyone,
someone will have a lisp that allows me to select an xref within a viewport and make a "VP FREEZE IN ALL VIEWPORTS EXCEPT CURRENT".
this lisp would be very useful.
I hope your help, thank you.
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
cadffm
If you want to freeze the insert-Layer of the Xref, than you can use plan VPLAYER-command
(Best practise to insert XREF on his own Insert-Layer, so kann can use VPLayer, freeze, except current vport)
If you want to freeze all Xref-Layer (MyXrefName|Layer1-99), that is without charme, and you need a short lisp for the Names
(strcat(cdr(assoc 2 (entget(car(entsel)))))"|*")
Sebastian
Edwin.Saez
@cadffm,
there is a way that it is by xref selection and take into account all the layers of that xref ?, because they will not always be the same layer that I want to keep.
Edwin Saez
Edwin.Saez
someone can help with this lisp please.. Smiley Sad
Edwin Saez
cadffm
Which help you need, ehats yout Problem, where is you Code?
Isn´t command VPLAYER a great way for that?
If you have the good way, special insertion Layer for seperate XRefs, you can use plaine VPLAYER,
if you want to freeze all Layer in the Xref, you hafe to create the right Namepattern XREFNAME|*
See my simple sample above
entsel,car,entget,assoc,cdr,strcat
_.VPLAYER
_freeze
xrefname|*
_x
Show us where you have problems.
Sebastian
