How to create a lisp to insert blocks with AutoLISP?
ireliontt
Message 1 of 11
ireliontt
So, I am kinda new to the AutoLisp world and I wanted to create a lisp that defines a command named "FF" to insert specific blocks. For example, the user types FF, then defines the first point and then types a string like "TFN". The thing is, in this string all characters are blocks, F corresponds to a block, and so do N and T. Here is the code:
(defun c:FF ()
(setq P (getpoint "Define origin:"))
(setvar aux 1)
(setq seq (getstring "Define the sequence of blocks:"))
(foreach str seq
     (command "insert" str (polar P (* pi 2) (aux*2)))
     (incf aux)
It's supossed to look like this:
By the way, the "aux" variable is used to create separation between the blocks.
Autocad 2010 does recognize the command FF, then requires a point, but when the point is defined it returns this: error: bad argument type: (or stringp symbolp): nil
Replies (10)
Message 2 of 11
paullimapa
since autocad does not have a system variable named aux you cannot do a setvar
I assume you want to do a setq:
(setq aux 1)
Also what is incf function?
(incf aux)
This should be defined somewhere at the beginning like (defun incf ()....
Paul Li
IT Specialist
@The Office
Message 3 of 11
Sea-Haven
 A few things missing in code something like this maybe.
(setq aux 100)
(setq pt (getpoint "\nPick start point"))
(while (/= (setq seq (getstring "Define the sequence of blocks Enter to exit:")) "")
 (command "-insert" seq "s" 1 pt 0.0)
 (setq pt (mapcar '+ pt (list aux 0.0 0.0)))
) ;endwhile
will help
Message 4 of 11
Kent1Cooper
In addition to issues others have raised....
(foreach) requires a list, not a text string.   Fortunately, there's an AutoLisp function that will turn a string into a list of ASCII character numbers, and from that list you can turn those back into individual-character text strings as Block names, assuming those single characters are, in fact, the Block names:
(foreach char (vl-string->list seq)
   (command "_.insert" (chr char) ....
In your example string:
(vl-string->list "TFN")
returns
(84 70 78)
and
(chr 84)
turns that first one back into "T".
Another possibility would be to use (substr) to pull each individual character out as a Block name, but I think a (repeat) or (while) function with a counter variable would be needed.
Kent Cooper, AIA
Message 5 of 11
ivanovsky
there are some bugs in your code, i fixed some,
here is my modified code,
(defun c:FF (/ aux p seq)
(setq aux 1)
(foreach str seq
     (command "insert" str (polar P (* pi 2) (* aux 2)))
     (incf aux)))
but,
the "exploding string" procedure is still to be modified,
you could use some other guy's reply.
Message 6 of 11
Sea-Haven
Further to Kents good idea try this.
(defun c:test ( / aux pt seq char )
(setq aux 100)
 (command "-insert" (chr char) "s" 1 pt 0.0)
) ;endforeach
(princ)
It would be better to use say a,b,c then can have aa,bbbbb,c.
Message 7 of 11
ireliontt
Thank you for the help guys. It's almost done, there's just one issue. Here is the current version of the code:
(defun c:FF ( / aux P fio char )
(setq P (getpoint "\nDefina a origem:"))
(setq aux 1)
(setq fio (getstring "\nEntre com a sequencia da fiacao:"))
(foreach char (vl-string->list fio)
 (command "-insert" (chr char) "s" 1 P 0.0)
 (setq P (mapcar '+ P (list aux 0.0 0.0)))
) ;endforeach
 Somehow, the code is inserting all three block as one:
Here is the Autocad prompt:
-insert Enter block name or [?] <N>: T
Units: Millimeters   Conversion:    1.0000
Specify insertion point or [Basepoint/Scale/Rotate]: s Specify scale factor for
XYZ axes <1>: 1 Specify insertion point or [Basepoint/Scale/Rotate]:
Specify rotation angle <0>: 0.000000000000000
Command: -insert Enter block name or [?] <T>: F
Units: Millimeters
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]: s Specify scale
factor for XYZ axes <1>: 1 Specify insertion point or
Command: -insert Enter block name or [?] <F>: N
Message 8 of 11
Kent1Cooper
Do you have running Object Snap mode(s) turned on?  Does it work if you do this?
(command "-insert" (chr char) "s" 1 "_non" P 0.0)
Kent Cooper, AIA
Message 9 of 11
ireliontt
Thank you man!! It works just fine now!!
Message 10 of 11
Kent1Cooper
You're welcome.  Just for general reference, any time things or parts of things are drawn but end up in different positions/locations than you expect, running Object Snap is the most likely culprit.  Second most likely is probably UCS differences.
Kent Cooper, AIA
Message 11 of 11
Sea-Haven
Like Kent's suggestion this is what I use in nearly all my code,
(defun c:FF ( / aux P fio char oldsnap)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
.... all the code
(setvar 'osmode oldsnap)
(princ)
If still problem try 16384 instead of 0.
