No need of installing for this such a small software for small job, Just a loading of Autolisp
From where did you downloaded that plug-in ?
Below Routine at https://www.lee-mac.com/totallengthandarea.html
;;--------------------=={ Total Length }==--------------------;;
;; Displays the total length of selected objects at the ;;
;; command line. The units and precision format of the ;;
;; printed result is dependent upon the settings of the ;;
;; LUNITS & LUPREC system variables respectively. ;;
;; Author: Lee Mac, Copyright © 2013 - www.lee-mac.com ;;
(defun c:tlen ( / e i l s )
(if (setq s
(ssget
'( (0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")
(-4 . "<NOT")
(-4 . "<AND")
(0 . "POLYLINE") (-4 . "&") (70 . 80)
(-4 . "AND>")
(-4 . "NOT>")
(progn
(setq l 0.0)
(repeat (setq i (sslength s))
(setq e (ssname s (setq i (1- i)))
l (+ l (vlax-curve-getdistatparam e (vlax-curve-getendparam e)))
(princ "\nTotal Length: ")
(princ (rtos l))
(princ)
(vl-load-com) (princ)
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
