Explode Only Polylines to lines
hanywillim
hanywillim
Hi Friends,
I am looking for a lisp to ONLY select the polylines in the model space and convert it to simple lines
Thanks in advance for any kind help ❤️
ronjonp
Sure..
(defun c:foo (/ s)
  (if (setq s (ssget "_X" '((0 . "*POLYLINE") (410 . "Model"))))
    (progn (initcommandversion) (command "_.explode" s ""))
  (princ)
hanywillim
Great bro,
Can you illustrate for me why it was written in the command bar that:
"Hatch boundary associativity removed."
but i tested, it will not delete the hatch and that is good for me.
ronjonp
@hanywillim
It won't delete the hatch nor explode because of the filter. What gets lost is the hatch boundary is no longer tied to the hatch because it's in pieces now.
Same behavior when manually done:
Command: X
EXPLODE 1 found
