how to Batch Convert Field attribute to text attribute in a block
Greetings,
I have 740 dwgs in one set of drawings and would like to "Covert Field To Text" on a tag of title block named "T2A-7", does anyone know how to Batch Convert Field attribute to text attribute in the block?
Peter
hmsilva
@Anonymous wrote:
Greetings,
Peter
Hi Peter,
one way using Acad Core Console:
  • change this pbejse's code with the correct block name and the correct TAG
  • this mracad's code to create a batch from AutoCAD
  • create a '*,scr' file to load pbejse's code, run it, save and close...
Hope this helps,
Henrique
