MTEXT opaque background color
How can I set the background color to opaque using lisp?
I tried using the following to set the offset value, but I don't know what the color code should be to come out opaque:
     (entmod (append ed1 '((90 . 0) (63 . 0) (45 . 1.25) (441 . 0))))
Larry
hmsilva
Larry
Opaque??
To color 255
(entmod (append ed1 '((90 . 1) (63 . 255) (45 . 1.25) (441 . 0))))
to background color
(entmod (append ed1 '((90 . 3) (63 . 256) (45 . 1.25) (441 . 0))))
Hope this helps,
Henrique
Thanks Henrique
I guess I should been more clear about what I meant by opaque.
I want to "use drawing background color".
I said opaque because that's what it says when you hover over the chackbox in the background mask dialog box (see attachment)
Both codes you specified gave me a white box around the text, I don't want any color around the text.
Sorry for the confusion
Larry
hmsilva
@Anonymous wrote:
Thanks Henrique
Larry
Hi Larry,
my second code, should use background color, did you also change dxf 90 to 3 ?
Henrique
My bad, I didn't notice you had changed the value of 90.
So yes, 90 . 3 and 63 . 256 worked perfectly
Thank you
Larry
hmsilva
You're welcome, Larry
Glad I could help
Henrique
