How to add space or double quotes?
Message 1 of 12
how to add space or double quotes in command?
OK
^C^C_setenv RDCambiaStato $M=$(eval,"RDCambiaStato.cmd_")$(getvar,dwgname);
I get RDCambiaStato_DWGNAME
KO
^C^C_setenv RDCambiaStato $M=$(eval,"RDCambiaStato.cmd ")$(getvar,dwgname);
I get RDCambiaStato ONLY and than dwgname,
cause space is like ENTER
How to fix it?
Thanks, regards Massimo
Replies (11)
Message 2 of 12
Moshe-A
diesel does not have a function setenv (only getenv same as it does not have setvar only getvar)
are you using AutoCAD LT?
Message 3 of 12
HEllo,
yes I'm using autocad LT.
^C^C_setenv RDCambiaStato $M=$(eval,"RDCambiaStato.cmd "$(getvar,dwgname)")
If I open test.dwg in Autocad LT, then I run
MODEMACRO
$(eval,"RDCambiaStato.cmd $(getvar,dwgname)")
I get :
RDCambiaStato.cmd TEST.DWG
But I need it WITH double quote
"RDCambiaStato.cmd TEST.DWG"
Is it possible some how?
Thanks, regards
Massimo
Message 4 of 12
Moshe-A
if environment variable RDCambiaStato is fixed why don't you set it in the macro?
Message 5 of 12
thanks for helping, try to better explain.
it's a general request.
My need is to add at the beginning and the end of a string double quotes.
Because _startapp with path containg spaces, will not work
if not "enclosed" by quotes.
I'm new to diesel and acad lt macro.
What I'm not able to do is something like (VBA just as an example)
Dim command as string
command = chr(34) & "RDCambiaStato.cmd " & DWGNAME & chr(34)
debug.print command
I will get
I'm not able to "build" a string, that contain double quotes
in DIESEL or COMMAND macro "syntax".
regards
Massimo
Message 6 of 12
ВeekeeCZ
I guess you've already tried the usual: Prefix " or \.
""TEST""
or
\"TEST\"
Message 7 of 12
Moshe-A
as far as i know startapp is an autolisp function
but in your acadlt.pgp there should be start command.
so did that and it works perfect
^C^Cstart $m=$(eval, notepad.exe);
i think no quotes is needed, the diesel (eval) function just takes your entry and makes it a string
Message 8 of 12
cadffm
No shell functions available from pgp in LT.
You can store your information without "" in one enviroment variable, "NextFile" for example, and start your program with mtexted trick or by AI_STARTAPP.
The external program have to do all other things (read the value of NextFile and do whateveryouwant with that information).
Sebastian
Message 9 of 12
thanks for info.
BUT If I need to pass the DWGname as parameter to AI_STARTAPP
as an example. AI_STARTAPP dosomething.cmd DWGNAME, where DWGNAME contain spaces?
Cause AI_STATAPP DOSOMETHING.cmd is working fine.
WHEN I need to pass DWGNAME as argument, I'm not able to do it.
Message 10 of 12
cadffm
Hi Massimo,
I know that and i described the workaround, so why do you repead the words about this (not working) direct way?
Sebastian
Message 11 of 12
Hello Sebastian,
thanks
pls can you write a "working" example on how to do it?
I can't figure out, that's why keep asking.
"Following" your instruction, I tried to create two enviroment variables:
1. NextFile (OK) : _setenv NextFile $M=$(getvar,dwgname)
2. MYCMD (OK) :  _setenv MYCMD "RDCambiaStato.cmd"
3. Start App with combination of MYCMD and Nextfile, inside quote (KO)
 _startapp "$(getvar,MYCMD) $(getvar,NextFile)"
But is not working for me.
Here the "full" command:
^C^C_setenv NextFile $M=$(getvar,dwgname) _setenv MYCMD "RDCambiaStato.cmd" GETENV NextFile;GETENV MYCMD;AI_STARTAPP "$(getvar,MYCMD) $(getvar,NextFile)"
Command Line Output:
Comando: _setenv Immettere il nome della variabile: NextFile Valore <$M=$(getvar,dwgname)>: $M=$(getvar,dwgname)
Comando: _setenv Immettere il nome della variabile: MYCMD Valore <RDCambiaStato.cmd>: "RDCambiaStato.cmd"
Comando: _startapp AI_STARTAPP "$(getvar,MYCMD) $(getvar,NextFile)"
Impossibile trovare l'applicazione $(getvar,MYCMD) $(getvar,NextFile).
>>Cannot find application $(getvar,MYCMD) $(getvar,NextFile).
Thanks, regards
Massimo
Message 12 of 12
**** UPDATE ****
Sorry, the full command is:
^C^C_setenv NextFile $M=$(getvar,dwgname) _setenv MYCMD "RDCambiaStato.cmd" GETENV NextFile;GETENV MYCMD;AI_STARTAPP $M=$(getenv,MYCMD) $M=$(getenv,NextFile)
Command Output:
_setenv Immettere il nome della variabile: NextFile Valore <Disegno2.dwg>: Disegno2.dwg
Comando: _setenv Immettere il nome della variabile: MYCMD Valore <RDCambiaStato.cmd>: RDCambiaStato.cmd
Comando: GETENV Immettere il nome della variabile: NextFile
Disegno2.dwg
Comando: GETENV Immettere il nome della variabile: MYCMD
RDCambiaStato.cmd
Comando: AI_STARTAPP RDCambiaStato.cmd
Comando: Disegno2.dwg Comando sconosciuto "DWG". Premere F1 per la Guida.
As you see, the space make the argument to be interpreted as a separate command.
Like if I run
AI_STARTAPP  RDCambiaStato.cmd (Enter)
Disegno2.dwg (Enter)
Thanks, regards
