Diesel how to get double quotes in eval a string?
how to get something like ?
$/eval,"\"Test \"")
I need the string with duoble quotes.
"Test"
Thanks, regards
Massimo
Moshe-A
this is form the manual:
DIESEL expressions return string values (text strings) that can be used as a response to standard commands, AutoLISP, and ObjectARX ® routines, and other macros
what are you trying to do exacly?
Hello
^C^C_setenv RDCambiaStato $M=$(eval,"RDCambiaStato.cmd "$(getvar,dwgname)")
If I open test.dwg in Autocad LT, then I run
MODEMACRO
$(eval,"RDCambiaStato.cmd $(getvar,dwgname)")
I get :
RDCambiaStato.cmd TEST.DWG
But I need it WITH double quote
"RDCambiaStato.cmd TEST.DWG"
Is it possible some how?
Moshe-A
i still not sure i understand what you want to do? why you keep saying you want it with double quotes?
when the documentation says the value return from diesel string expresstions is a string compatiable with autolisp
Are you familer with USERS1-USERS5 system variables?
you can store in them any string value you want and use them in diesel
like if you want to put a space between 2 sysvars do that:
invoke USERS1 and respond with space (you will see noting)
than...
MODEMACRO
$(getenv,RDCambiaStato.cmd)$(getvar, users1)$(getvar,dwgname)
does that do what you after?
p.s
USERS1-USERS5 are not saved and each time you open a dwg you have to set them
so you have to design a special macro for setting them
also exists USERI1-USERI5   for integer numbers
also exists USERR1-USERR5 for real numbers
cadffm
Users1-5 is not available in LT.
Sebastian
john.uhden
Users1-5 are not available in LT, you bumbleheaded misanthrope.
[Don't worry, onlookers.  He knows that's a sign of affection.  It's quite different from calling him a $#&!@+]
John F. Uhden
