find text & use in programme
Message 1 of 12
I have attached lisp programme. In which I manually select the text to arrange it in sequence. But in my drawing I am selecting the text only which have prefix "TBA-" So is it possible to update my existing programme for automatic selection of text which consist of prefix "TBA-" instead of selecting them manually. This will reduce my lots of time. Thanks!
Replies (11)
Message 2 of 12
ВeekeeCZ
Try to replace this part
(ssget '((0 . "TEXT") (1 . "*-*")))
with this:
(ssget "_X" (list (0 . "TEXT") (1 . "TBA-*") (cons 410 (getvar 'CTAB))))
Otherwise you could kindly ask the author.
Message 3 of 12
Thanks for the solution. I tried this but it shows error that "no function definition: GETLST". Please refer attached updated program. Is it correctly updated?
Message 4 of 12
dbhunia
Hi Archana,
Try the attached code......
At the time of execution of code, if you don't want to move the selected text then press "Esc" once to deselect the text and press "Enter" to continue with next text. To terminate the execution of code at any stage press "Esc" twice.
Debashis
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 5 of 12
Hello Debashis, Thanks for the code! But my requirement is different. Please refer attached test.dwg file for exact requirement.
Message 6 of 12
dbhunia
Hi Archana,
I have resolved the selection problem......
hopefully you can sort out the rest ........
Debashis Bhunia
Message 7 of 12
Thanks for your prompt reply! It is working but while inserting the final result, it insert first one box then on next click it insert 1st & 2nd box, then on next click it insert 1st,2nd &3rd box, likewise. I want all boxwes only in one click. Please help!
Message 8 of 12
ВeekeeCZ
Sorry, my bad, it should be:
(ssget "_X" (list '(0 . "TEXT") '(1 . "TBA-*") (cons 410 (getvar 'CTAB))))
That should resolve your "no function definition" issue.
Message 9 of 12
dbhunia
ok I will give me some time......
Debashis Bhunia
Message 10 of 12
dbhunia
Hi Archana,
Try this code.....
(It has been tested in "AutoCAD 2007", hope fully it will work in latest version. Otherwise you have to wait till Monday)
Debashis Bhunia
Message 11 of 12
Thank you very much! It works!
Message 12 of 12
dbhunia
Hi Archana,
If it is Working then Accept the solution....
Debashis Bhunia
