Lisp to select all dimensions with same text override.
Message 1 of 8
I would like to know if anyone has a LISP for selecting all dimensions with same text override. I would like to run it on open drawing. On running the lisp it should ask to select a dimension with override already applied and then it should select all the dimension with the same override in the file and should end with all dimension selected so that i can apply any change on that selection set. We have to perform this work through qselect. But it takes some time , i want to automate this through lisp but have no idea.
Thanks to anyone that has something like that and wants to share.
Replies (7)
Message 2 of 8
Moshe-A
hi,
check this one:
note, the current and the new dimtxt values must be a whole numbers  (e.g integers)
enjoy
moshe
(defun c:dimtxtovr (/ val0 val1 ss elist ctr)
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (if (and
       (setq val0 (rtos (getreal "\nCurrent dimtxt: ") 2 0))
       (setq val1 (rtos (getreal "\nSet new dimtxt: ") 2 0))
       (setq ss (ssget "x" '((0 . "dimension"))))
  (progn
   (setq i -1 ctr 0)
   (repeat (sslength ss)
    (setq elist (entget (ssname ss (setq i (1+ i)))))
    (if (and
	  (/= (cdr (assoc '1 elist)) "")
	  (eq (cdr (assoc '1 elist)) val0)
     (progn
      (setq ctr (1+ ctr))
      (entmod (subst (cons '1 val1) (assoc '1 elist) elist))
   ); repeat
   (if (= ctr 0)
    (prompt "\nNoting found.")
  ); progn
 ); if
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
Message 3 of 8
pbejse
@Anonymous wrote:
..select a dimension with override already applied and then it should select all the dimension with the same override in the file and should end with all dimension selected ...
(defun c:FFD (/ seldim str);; <- Find Fudge Dimension
  (if (and
	(setq seldim
	       (ssget "_:S:E"
		      '((0 . "*DIMENSION")
			(-4 . "<OR")
			(1 . "*?*")
			(-3 ("ACAD"))
			(-4 . "OR>")
	       ) ;_ end of ssget
	) ;_ end of setq
	(setq str (cdr (assoc 1 (entget (ssname seldim 0)))))
      ) ;_ end of and
    (sssetfirst
      nil
      (ssget "_X" (list '(0 . "*DIMENSION") (cons 1 str)))
    ) ;_ end of sssetfirst
  ) ;_ end of if
  (princ)
HTH
Message 4 of 8
_Tharwat
This?
(defun c:Test ( / str )
  (and (setq str (getstring t "\nSpecify text override to search for :"))
       (sssetfirst nil (ssget "_X" (list '(0 . "*DIMENSION") (cons 1 str) (cons 410 (getvar 'CTAB)))))
  (princ)
Message 5 of 8
Thanks pbejse's sir,
That was exactly what I wanted . thank you once again.
Message 6 of 8
braudpat
Hello Mr @pbejse
I like your routine so Kudos for you !
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 7 of 8
harry.jaff.swift
Hi, this is amazing!
Is it possible to select all of the M-texts that have the same height with the same principal?
I Have an AutoCAD 2D model,  that contains lots of different text sizes and I wanna be able to select specific text size and make them a little smaller but not the same as other texts on the model!   thank yo in advance!
Message 8 of 8
braudpat
Hello @harry.jaff.swift
Please create a new Topic with your demand relative to MTEXT!
Thanks, The Health, Bye, Patrice
Patrice BRAUD
