How many Pendrive
How many Pendrive
How many Pendrive
I want to know through lisp how many pendrive are connected to the pc.
To go through each one and read its physical direction.
Is this possible with lisp?
thanks...
Scottu2
jose.diaz.montejo, you could have a lisp routine to test writing a file to the specified drive (usb drive).  If it fails then either it does not exist or insufficient rights to access the drive, otherwise it does exist and keep track of that drive letter.
Is a pendrive a usb drive?
Please clarify "read its physical direction".
trevor.bird.au
Hi Jose,
The following program will identify pen drives:
;;  PenDrives.lsp by Trevor Bird
;;  2017-07-29
(defun c:pendrives
    DriveType
    IsReady
    obj_FSO
  (setq obj_FSO (vlax-create-object "Scripting.FileSystemObject"))
  (vlax-for vf::obj_Drive (vlax-get-property obj_FSO 'Drives)
    (setq IsReady   (vlax-get-property vf::obj_Drive 'IsReady)
          DriveType (vlax-get-property vf::obj_Drive 'DriveType)
    );setq
    (if (and (= IsReady :vlax-true)
             (= DriveType 1)
        );and
      (progn
        (princ "\nDrive ")
        (princ (vlax-get-property vf::obj_Drive 'DriveLetter))
        (princ ": = Removable")
      );progn
    );if
  );vf::obj_Drive
  (vlax-release-object obj_FSO)
  (princ)
);c:pendrives
Trevor
I have been reading that there are two identification numbers for a USB (serialnumber and Physicalmedia),
Serialnumber: if you Format the USB this changes.
PhysicalMedia: if you Format the USB does not change.
And I need Physicalmedia.
Thanks.
Scottu2
jose,
Try the lisp routine by SonikSSV.
Run the pendrives.lsp
When there is no drive plugged into the computer it reports nothing.
If there is a pendrive plugged into the computer the program displays the drive letter.
If the pendrive was not formatted, then the program would not detected, thus report nothing.
Did you want see the physical media information, like 32FAT, NTFS, bytes used or bytes free?
I have tried the routine pendrive.lsp, and I have modified it and add another one that I find.
And it gives the expected result.
Only the SerialNumber data changes if the USB is formatted.
Also read on a page that this data, can be manipulated easily, so that the user could clone the same data in several USB.
That's why I need to find the physical and irreplaceable USB serial.
;;Programa para ligar una unidad de almacenamiento con su serial
(defun Serial_Usb ()
(setq set:prod 0)
	(setq driveL 	(vlax-get-property vf::obj_Drive 'DriveLetter))
	(setq physical_drive 1616258636)
	(setq getph_drive (DriveSerial (strcat driveL ":")))
	(alert (strcat driveL ":"))
	(if (= physical_drive getph_drive)
		(setq set:prod 1)
	);end if
);end defun
(defun DriveSerial (drive / *error* sys serial drive)
  ;; Get specified drive's serial number
  ;; drive - string of drive in question (eg. "c:" or "c")
  (defun *error* (m)
    (mapcar
      (function (lambda (x) (vl-catch-all-apply (function vlax-release-object) (list x))))
      (list drive sys)
  (if (setq sys (vlax-create-object "Scripting.FileSystemObject"))
    (setq serial (vlax-get (setq drive (vlax-invoke sys 'GetDrive drive)) 'SerialNumber))
  (*error* nil)
  serial
Scottu2
Jose,
Nice routine.
It may not be a significant problem but the variable DRIVE appears in the public and private variable definitions.
If the USB drive does not have a permanent ID number then i would suggest that you create a text file called DISK.ID on the USB.
DISK.ID file format
Line1: Serial number
Line2: Description
Line3: Date created
Keep track of the new numbers
Append the new serial number to a log file and
then write the DISK.ID with that new serial number to the USB.
Read the DISK.ID and display the lines
and check the serial number against the log file
