Xref loop routine
Xref loop routine
andreas7ZYXQ
Message 1 of 14
Xref loop routine
andreas7ZYXQ
Im working on a script that will change my xrefs and save it.
Im planning to run a foreach on the code and i would like to replace StringtoFind with "a b c d" stored in a list.
I would like to change a part of the text inside a attribute, a part of a xrefs name and path and then save.
Then step to the next in my list and so on.
When i run my code i get a error message like "error: bad argument type: consp "RITNINGSNR.""
Im guessing the datatype is wrong? I was searching about (vl-princ-to-string) but im not sure if this is the way to go.
I got stuck how to fix that, any suggestions?
Other ideas and thoughts about the code are warm welcome since im a beginner.
(vl-load-com)
;------User input here---------------------------
;------------------------------------------------ (setq a "63B");<---- Category 1 here (setq b "63F");<---- Category 2 here (setq c "64");<----Category 3 here (setq d "64CBB");<----Category 4 here
;------------------------------------------------ (setq StringtoPut(list a b c d)) (foreach StringtoPut (setq StringtoFind "61" Attnamn "RITNINGSNR.");setq (setq ss (entnext)) (while ss (setq ed (entget ss)) (if (= Attnamn (cdr (assoc 2 ed))) (entmod (subst (cons 1 (vl-string-subst StringtoPut StringtoFind (cdr (assoc 1 ed))))(assoc 1 ed)ed)) ) (setq ss (entnext ss)) ) (vlax-for MyXref (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)));<--go through all block objects (if (and (vl-string-search (strcase StringtoFind) (strcase (vla-get-name MyXref)));<---if the name contains your string (= (vla-get-isxref MyXref) :vlax-true);<---if it's an xref ) (progn (vla-put-name myxref (vl-string-subst StringtoPut;<---Change the name (substr (vla-get-name MyXref) (1+ (vl-string-search (strcase StringtoFind) (strcase (vla-get-name MyXref)))) (strlen StringtoFind));substr (vla-get-name myxref) );string subst );vla-put-name (vla-put-path myxref (vl-string-subst StringtoPut;<---Change the Path (substr (vla-get-path MyXref) (1+ (vl-string-search (strcase StringtoFind) (strcase (vla-get-path MyXref)))) (strlen StringtoFind));substr (vla-get-path myxref) );string subst );vla-put-path (vla-reload myxref) );progn );if );vlax-for (princ) ;(command "qsave") ;(command "close") (setq filnamn(vl-filename-base(getvar "dwgname"))) (setq newname(vl-string-subst StringtoPut StringtoFind filnamn)) (setq file (strcat (getvar 'dwgprefix) newname ".dwg")) (if (findfile file) (command "_.-wblock" file "Y" "*") (command "_.-wblock" file "*") ) )
Replies (13)
Message 2 of 14
cadffm
Without testing your code and my try for solution
(eval (list 'vl-string-subst StringtoPut StringtoFind (cdr (assoc 1 ed)))
Sebastian
Message 3 of 14
andreas7ZYXQ
@cadffm I got the same error..
	  (entmod (subst (cons 1 (eval (list 'vl-string-subst StringtoPut StringtoFind (cdr (assoc 1 ed)))))(assoc 1 ed)ed))
Message 4 of 14
cadffm
Arghh
Skip
Write
(foreach StringtoPut (list a b c d)
or
(setq StringtoPutList (list a b c d))
(foreach StringtoPut StringtoPutList
consp = data type of cons arg is wrong
Sebastian
Message 5 of 14
pbejse
So there are two items,
1. Rename and repath the xref.
2. Pass the new xrefnaem to an attribute on a block.
On your code, you are targeting "61" as part of the xref name / attdef tag name. Is this always the case?  or StringtoFind variable varies from one project to another? "RITNINGSNR." is the targeted tag name?
Message 6 of 14
andreas7ZYXQ
I just got it working
thanks @cadffm
yes @pbejse 61 is always the target. Or i will just change "leta" to whatever i want to replace.
But..
The reason i setq a b c d is to have a easy user imput for those who dont know about lisp. (or maybe there is even a better way, but it the way i know how to  :P)
I just have a small issue. For example "d" is left empty. Then i dont want it to cause problems with my list.
(vl-load-com)
(setq leta "61")
(setq a "63B")
(setq b "63F")
(setq c "64")
(setq d "")
(setq StringtoFind leta	Attnamn "RITNINGSNR.");setq
	(setq ss (entnext))
	(while ss
   (if (and
     (progn
			      );string subst
	 );vla-put-name
			      );string subst
	 );vla-put-path
       (vla-reload myxref)
       );progn
     );if
   );vlax-for
  (princ)
;(command "qsave")
;(command "close")
(setq newname(vl-string-subst StringtoPut leta filnamn))
(if (findfile file)
(setq StringtoFind StringtoPut)
Message 7 of 14
pbejse
But..
Something very odd the way your code is written. anyways for the issue you can..
(foreach StringtoPut  (vl-remove-if '(lambda (v)(eq v ""))(list a b c d))
Message 8 of 14
andreas7ZYXQ
Thanks @pbejse!
Curious to know, what do you mean by odd. Is there some part that needs improvement?
Message 9 of 14
pbejse
Thanks @pbejse!
	   (if (and
		 (vl-string-search
When this is TRUE for the first element on the foreach items (list a b c d), say for the item "63B" , when StringtoFind is found , the xref will be renamed and repath , there would be no point running the rest of the list, unless the StringtoFind variable change for every iteration as well
Message 10 of 14
pbejse
Consider a re-write for this as well..same issue
	(while ss
	 (setq ed (entget ss))....
Tell us, what is the block name where the attribute needed to be change?  We can improve the code by running just once and consider all conditions for (list a b c d).
I suggest you use some an association list like this to test fro conditions
(setq XrefNameOldAndNew
           '(("61" "63B")
             ("54" "63F")
             ("AB" "64")
Message 11 of 14
andreas7ZYXQ
I think i just got lost now, hehe. its starting to get above my level of knowledge 😞 .
I will try to explain my process..
I normally have 2 xrefs in my E-61-1-100.dwg.
E-61-100.dwg [..\directory\E-61-100.dwg]
F-61.dwg [..\directory\F-61.dwg]
I have a block name that always change name from project to project and also the attribute. So always change attribute name manually.
Lets say the name is RITNINGSNR. this time, this is where my drawingname is printed "E-61-1-100"
My main goal is to make exact copies of this file and save it. Before its saved i want to change xref and my drawingname inside RITNINGNR.
So my new file should be like..
E-63B-1-100.dwg
Xrefs:
E-63B-100.dwg [..\directory\E-63B-100.dwg]
F-63B.dwg [..\directory\F-63B.dwg]
RITNINGSNR.
E-63B-1-100
E-63F-1-100.dwg
Xrefs:
E-63F-100.dwg [..\directory\E-63F-100.dwg]
F-63F.dwg [..\directory\F-63F.dwg]
RITNINGSNR.
E-63F-1-100
"63B / 63F" can change from project to project so i have to decide that every time i want to run. It could be 65 or 66.
Message 12 of 14
pbejse
I will try to explain my process...
I guess you are on the right track then, only thing you need to change is put search for the XREF at the start, (outside of foreach), if found then start iterating the names your list.
Message 13 of 14
pbejse
Apologies for I did not notice this addition at post#6 .
that really makes a big difference andreas7ZYXQ.
Message 14 of 14
andreas7ZYXQ
No worries @pbejse. Im always happy to have differents inputs. Keeps the head going. 😃
Thanks alot for the help, worth alot!
