hob.lsp
hob.lsp
hob.lsp
I'm looking for the old hob.lsp file. Is it still available? My email address is jamessean517@gmail.com
Kent1Cooper
Have you Searched, on the internet generally as well as on these Forums?  What does it do?  Someone may have something else that does the same thing, if you can't find it.
Kent Cooper, AIA
john.uhden
Kent1Cooper
If gear teeth are what it's about, >>here<< is a thread with some related routines, as well as some links to other possibilities.
Kent Cooper, AIA
lando7189
Is it this?
(defun c:HOB ()
   (command "SNAP" "OFF")
   (setq cpg (list 0 0))
   (setq ntg (getreal "\nEnter number of teeth on gear: "))
   (setq ngh 18)
   (setq odg (+ 2 ngh))
   (setq pdg (getreal "\nEnter generating pitch dia of gear: "))
   (setq dpg 1.000)
   (setq xi (/ (* -0.25 pi pdg) ntg))
   (setq mx (/ pi ngh 2))
   (setq sph (list (* -48.0 mx) (* 0.5 pdg)))
   (setq rot (/ -180.0 (* ntg ngh)))
   (setq cnt -51)
   (setq pt1 (list (* -2.2 odg) (* -1.85 odg)))
   (setq pt2 (list (* 2.2 odg) (* 1.85 odg)))
  (command "OSNAP" "OFF")
   (command "zoom" "w" pt1 pt2)
  (while (< cnt 51)
  (progn
     (command "INSERT" "HOB" sph 1 1 0 )
     (command "rotate" "W" pt1 pt2 "" cpg rot)
     (setq sph (list (+ (car sph) mx) (cadr sph)))
     (setq cnt (+ cnt 1))
Source:
http://www.eng-tips.com/viewthread.cfm?qid=67055
No, it isn't. The lisp file I'm talking about draws the gear and generates
the gear data as text in the drawing/
lando7189
How about this?  It says it was HobMaster back in 1994 but became MyGEARilla over the years.  It appears the Author retired in 2009... but searching for it appears difficult.
https://www.scribd.com/document/26586523/My-Gear-Ill-a-Help-and-Legal
