Background Mask in Text Styles
Hi all,
Has anyone heard of an add-in, lisp or work-around that would allow one to effect background mask as a text style setting?  If not, I'd like to submit it as an idea for future versions of AutoCAD.
Ryan
AutoCAD 2013, Windows 7, 64-bit
imadHabash
does this routine help . >> Click <<
Imad Habash
Thanks for your response.
That lisp does make it a little easier to add background mask to text but, I'm looking for a way for the feature to be added automatically to all text and not have to go back and manually turn it off and on.
ВeekeeCZ
Try this lisp to create new MTEXT.
(vl-load-com)
(defun c:MtextMasked (/ enl obj)
  (setq enl (entlast))
  (command "_.MTEXT" pause pause "Text" "")
  (and (not (equal enl (entlast)))
       (setq obj (vlax-ename->vla-object (entlast)))
       (not (vla-put-backgroundfill obj :vlax-true))
       (not (vla-put-textstring obj ""))
       (command "_.MTEDIT" "_L"))
  (princ)
And no, the mask can't be added to a text style in any way, so you may consider to submit this as an idea.
