Wblock named block to specific path/directory
Message 1 of 10
Hello, I've already tried to search here in forum a LISP for this task and all over Internet, but I can't find a LISP to accomplish this task at any place. Basically, I would like to Wblock a specific named block (like "B-IMP-", for example), to some specific predefined path/directory, or as a second option (if possible), to the same folder/directory where the file that will be "Wblocked/Opened file/Original File" is located, without being necessary any input from user. Just load the LISP and it's done, the file will be exported with only the "B-IMP-" block, the file will be named "B-IMP-.dwg" (same name as the exported block) and in the correct predefined folder/directory or in the original file path.
Is there any easy way of accomplishing that? How difficult is to write a LISP for that?
Thanks in advance for all good souls here...
Accepted solutions (3)
Replies (9)
Message 2 of 10
_gile
Something like this?
(if (tblsearch "block" "B-IMP-")
  (command "_.wblock"
           (strcat (getvar 'dwgprefix) "B-IMP-.dwg")
           "B-IMP-"
Gilles Chanteau
GileCAD
GitHub
Message 3 of 10
  (command "_.wblock"
           "B-IMP-"
Ow, amazing! Many thanks for that mate! From what I know about LISP the part when you tell the path/directory to be exported is here no?
If I want to export the drawing using Wblock to some specific folder/path, so the "Wblocked" file will always appears on Desktop or any other choosen folder, how can I use this?
I almost got it working to export to Desktop by the following code:
(command "_.wblock"
(strcat (getenv "UserProfile") "\\Desktop" "B-IMP-.dwg")
"B-IMP-"
Thnks a lote for your help!
Message 4 of 10
_gile
The strcat function concatenates the strings passed as arguments.
With AutoLISP the backslash (\) is the escape character, so if you need to use it in a string, you have 'escape' it: "\\".
With AutoLISP you cannot directly use the environnment variable shortcuts (as %systemdrive% or "%username%"), you have to use the getenv function.
That said, you can use:
(strcat (getenv "userprofile") "\\Desktop\\B-IMP-.dwg")
Gilles Chanteau
GileCAD
GitHub
Message 5 of 10
Worked 100%! Genious!
One last question mate, if I want to plug any other directory on server or at the computer, like for example "V:\BLOCKS\EXPORTED\B-IMP.dwg", how can I achieve that?
Thanks for your amazing support and for sharing your knowledge!
Message 6 of 10
_gile
As said upper, for hard coded path strings, just replace the backslash (\) directory separators with double backslashes (\\) (or single slashes (/)):
"V:\\BLOCKS\\EXPORTED\\B-IMP.dwg"
or
"V:/BLOCKS/EXPORTED/B-IMP.dwg"
Gilles Chanteau
GileCAD
GitHub
Message 7 of 10
or
Thanks Gile! This post will help someone else for sure. I've accepted all your solutions. Thanks for your help and time! 🙂
Message 8 of 10
emsquare.arch
Hello Gale,
Hope you are doing good.
Nice to see your response. Iam also looking for the wblock lisp but my requirements is little bit different.
I will have polyline (Floor plan) with multiple unit numbers and multiple floors in one drawing. If I want to make wblock I have to select each floor individually, give the name, location etc as per local methodology. But What Iam looking is if I select all floors then tool must make separate wblock for each floor based on the polyline line weight 0.07mm and give the name also based on line weight 0.07mm. I have attached a rough sketch for reference.
Please have a look and help me in this regard.
Saad
Message 9 of 10
devitg
Hi   , please upload YOUR-sample.dwg , as up now, acad can not edit , or lisp can not manage a hand made sketch
Message 10 of 10
emsquare.arch
Hello
Just give me some time I will upload the sample drawing.
