Help with vl-remove
Help with vl-remove
msarqui
Help with vl-remove
msarqui
Hi guys,
I am pretty sure that the code below can be written in a better way to avoid the repetition (in red).
I am asking because if I have a large list to remove, I will have a lot of repetition.
Could you help me please?
(vlax-for lay (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(setq laylst (cons (vla-get-name lay) laylst))
(foreach layname laylst
(if (not (member layname laylstfinal))
	(setq laylstfinal (cons layname laylstfinal)))
(setq remove0 "0")
(setq removeD "Defpoints")
(setq laylstfinal (vl-remove remove0 laylstfinal))
(setq laylstfinal (vl-remove removeD laylstfinal))
Marcelo
Marcelo,
Try this approach..
(if (and
     (/= layname "0")(/= layname "Defpoints")
   ); and
); if
Bob
ECCAD
msarqui
I can not believe I was not seeing this... 🙂
Many thanks ECCAD!
Kent1Cooper
It can be simpler than that [no (foreach) with embedded (if) / (setq) / (cons) functions needed]:
(setq laylstfinal (vl-remove-if '(lambda (x) (wcmatch x "0,DEFPOINTS")) laylst))
EDIT:
And you can do the initial layer-list part with less code, too:
(while (setq lay (cdadr (tblnext "layer" (not lay))))
  (setq laylst (cons lay laylst))
Kent Cooper, AIA
msarqui
Many thanks Kent!
It is a very cool solution. I will study more about LAMBDA.
Marcelo
