Lisp command
Lisp command
Tony_Gibbs
Lisp command
Tony_Gibbs
Hi All Can somebody help with this small problem I have finishing this lisp program. I have gotten it to BEFORE picture and need to get it to the AFTER picture. I've been trying to get the FILLET to do it in lisp but with no luck. Regards Tony
hmsilva
Hi Tony,
the 'lisp program', 'BEFORE picture' and the 'AFTER picture'?
There are no attachments...
Henrique
Tony_Gibbs
Hi All
Regards Tony
dbroad
If you are going to program a solution, have the program draw it correctly in the first place based on geometry rules.  If you need help finishing the lisp you've begun, I suggest posting the LISP you already have.
Architect, Registered NC, VA, SC, & GA.
Kent1Cooper
@Tony_Gibbs wrote:
.... I've been trying to get the FILLET to do it in lisp but with no luck. Regards Tony
If you've tried feeding entity names for those Lines to the Fillet command, try instead feeding it points, whether as points per se or as what is returned by (entsel) [a list of the entity name and the point where it was picked].  Fillet needs a location, not just an object, since where something is picked can affect which end of the object is adjusted to fillet with some other object.
Kent Cooper, AIA
