Help with vl-catch-all-apply
msarqui
Message 1 of 8
msarqui
Hello guys,
I have this routine thanks to the great work of BeekeeCZ
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/erase-all-but/m-p/5926425
It will delete all objects outside specific rectangles. I made small modifications to fit my needs and everything works great 99% of the time.
(defun c:EOUT (/ spol sall sint i n e)
(if	(and
	(setq spol (ssget "_X" '((0 . "LWPOLYLINE") (410 . "Model") (-4 . "<OR") (8 . "Tx-Viewport") (8 . "Tx-Contour") (-4 . "OR>"))))
	(setq sall (ssget "_X" '((0 . "~IMAGE") (410 . "Model") (-4 . "<AND") (-4 . "<NOT") (-4 . "<OR") (8 . "Tx-Viewport") (8 . "Tx-Contour") (-4 . "OR>")  (-4 . "NOT>") (-4 . "AND>"))))
	);and
	(progn
		(setq i -1)
		(repeat (setq i (sslength spol))
		(setq sint (ssget "_CP" (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (ssname spol (setq i (1- i))))))))
			(repeat (setq n (sslength sint))
				(if	(ssmemb (setq e (ssname sint (setq n (1- n)))) sall)
					(ssdel e sall)
				);if
			);repeat
		);repeat
	);progn
);if
(if	sall
	(command "_.ERASE" sall "")
);if
From time to time, something inexplicable happens and the routine crashes.
In my tests, the SSGET with CP gets an error in the LAMBDA that I do not understand. Maybe the file is corrupt or something. I attached two files, one that works and one that does not.
So my goal is to capture this error with a "vl-catch-all-apply" to avoid erase if the error occurs. But obviously I'm not having success. Could someone please help me?
This is what I get so far:
(defun c:EOUT (/ spol sall sint i n e errobj)
(if	(and
	);and
	(progn
		(setq i -1)
		(setq sint (ssget "_CP" (mapcar 'cdr (vl-remove-if-not (setq errobj (vl-catch-all-apply '(lambda (x) (= (car x) 10)) (entget (ssname spol (setq i (1- i))))))))))
		(if (vl-catch-all-error-p errobj)
			(print (strcat "An error occurred: " (vl-catch-all-error-message errobj)))
					(ssdel e sall)
				);if
			);repeat
		);if
		);repeat
	);progn
);if
(if	(and sall (null errobj))
);if
);defun
Marcelo
Replies (7)
Message 2 of 8
dbroad
You shouldn't try to nest something that will result in an error object inside an ssget statement or mapcar statement. Move the step that generates a point list to before the ssget, test the list to see if it is a list and then run the ssget.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 8
ВeekeeCZ
Can't answer your question, even I don't know why you're receive the error, but let's see if (foreach) can handle your 1%. Your bad-sample did. - edit: Probably just lucky coincidence. 😞
(defun c:EOUT (/ spol sall sint i n e e10)
  (if	(and
          );and
    (progn
      ;(setq i -1) why??
                                        (progn
                                          (foreach e (entget (ssname spol (setq i (1- i))))
                                            (if (= (car e) 10)
                                              (setq e10 (cons e e10))))
                                          e10))))
            (ssdel e sall)
            );if
          );repeat
        );repeat
      );progn
    );if
  (if	sall
    );if
Message 4 of 8
msarqui
Hi Bee,
I really appreciate your help.
;(setq i -1) why??
Sorry for that. My knowledge is limited and sometimes I mess things.
Your new solution still not works for me. Maybe because I have AutoCAD 2016? I do not know.
The routine stops here:
Because "sint" is nil. AutoCAD gives me: ; error: bad argument type: lselsetp nil
Message 5 of 8
ВeekeeCZ
Just wondering, how did you make those files? How did you fix the bad one?
I've found the one way how to fix it - using SUPERFLATTEN on the block inside. I see no obvious reason why is that. The both files looks the same to me.
BTW the issue is that (ssget "_CP"...) return nil even the list supplied with looks good.
So you should test that...
(if (setq sint ...)
 (repeat ...)
 (princ "The routine failed for some reason."))
(written before your last post)
Message 6 of 8
msarqui
It is really weird.
To make the GOOD, I took one file that I knew it was working and I erased everything (just to improve speed in tests), except what you see.
To make the BAD, I took a problematic file, I erased everything and copy/paste the objects from the GOOD.
So, both files have the same objects. That's why I thing this is a file problem (corrupted).
I am doing some tests with your suggestion, (if (setq sint ...) and I will come back later.
Message 7 of 8
ВeekeeCZ
Sorry, bad day. Gimme your first idea what could be a reason - that simple it is. 😞
That does not changes the fact, that routine is not good enough...
(defun c:EOUT (/ spol sall sint srem i n e)
  (if (and (setq spol (ssget "_X" '((0 . "LWPOLYLINE") (410 . "Model") (-4 . "<OR") (8 . "Tx-Viewport") (8 . "Tx-Contour") (-4 . "OR>"))))
           (setq srem (ssadd))
      (if (setq sint (ssget "_CP" (mapcar
                                    '(lambda (x) (trans x 0 1))
                                    (mapcar
                                      'cdr
                                      (vl-remove-if-not
            (ssadd e srem))))))
  (if (and srem
           (< 0 (sslength srem))
    (command "_.ERASE" sall "_R" srem ""))
  (princ)
Giving you a chance to guess. The reason: GURCYNARVFERIREFRQWHFGGLCRHPFJBEYQ
Go HERE if you give up.
Message 8 of 8
msarqui
You are kidding me? "Just" that?
Wow!
Just for the record, I think you missed a parenthesis here:
(< 0 (sslength srem)) )
I am really glad that you found the answer. I could not imagine that a UCS can do such "damage" in a routine.
Thanks for your help, it is priceless.
Marcelo
