Erase All But...
Erase All But...
msarqui
Erase All But...
msarqui
Hi guys,
I have this idea in mind for a long time and I would like to ask if it is possible to execute.
In the attached file, I have several rectangles. Notice that the rectangles are always in a specific layer. Also, I have several objects drawn (it could be any kind of AutoCAD object in any possible layer).
My question is:
Could I have a routine that will erase all the objects that are completely outside those rectangles? I know I can type ERASE, ALL and then REMOVE those rectangles areas with a window selection but in a large file this will be a waste of time.
Notice that some rectangles are overlapping, or within each other. So the routine should only consider the largest rectangle, or their outer boundary. I know Lee have this routine to make outline of selected objects http://www.lee-mac.com/outlineobjects.html (maybe it could be a start...)
I have AutoCAD 2012 but soon we will change for 2016.
Thanks!
ВeekeeCZ
Try this one...
(vl-load-com)
(defun C:EraseOutside (/ en ss sa si sai i ed e pts )
  (if (and (setq en (car (entsel "\nSelect countour object for layer: ")))
           (setq ss (ssget "_A" (list (assoc 8 (entget en)))))
	   (setq sa (ssget "_A" (list (cons 8 (strcat "~" (cdr (assoc 8 (entget en))))))))
	   (setq sai (ssadd))
    (repeat (setq i (sslength ss))
      (setq ed (entget (ssname ss (setq i (1- i))))
	    pts (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) ed)))
      (if (setq si (ssget "_CP" pts))
        (repeat (setq n (sslength si))
	  (if (not (ssmemb (setq e (ssname si (setq n (1- n)))) sai))
	    (ssadd e sai))))))
  (if sai (repeat (setq i (sslength sai))
	    (ssdel (ssname sai (setq i (1- i))) sa)))
  (if sa (command "_.ERASE" sa ""))
  (princ)
ВeekeeCZ
One more look into it... two loops looks like just enough.
(vl-load-com)
(defun C:EraseOutside (/ en ss sa si i)
  (if (and (setq en (car (entsel "\nSelect contour: ")))
      (if (setq si (ssget "_CP" (mapcar 'cdr (vl-remove-if-not
					       (entget (ssname ss (setq i (1- i))))))))
	  (if (ssmemb (setq e (ssname si (setq n (1- n)))) sa)
	    (ssdel e sa))))))
  (princ)
msarqui
Working like a charm.
Thank you very much BeekeeCZ!
from esteem of structural software (beam and slab section) .. every detail is disorganized .. what LSP can do automatic stacking this section beam and slab in one tittle block  ..tq
msarqui
If you are also interested on this routine please go HERE to watch the final chapter!
